CME 4.0: 7940 displaying wrong time, 7911G displaying the right time info
I have got the following setup:
IOS version 12.4.(4)XC7 (CME version 4.0) with 7911G en 7940G phones.
We have the following problem : on 7911G, the time is right, however, on
2 7940, the time is incorrect. (1 hour difference)
Any idea how to troubleshoot on this ?
Many Thanks
Dirk
show version
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version
12.4(4)XC7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 01-Aug-07 00:15 by alnguyen
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
CSPRAGUE2 uptime is 17 hours, 52 minutes
System returned to ROM by reload at 17:48:28 CET Mon Dec 3 2007
System restarted at 17:51:04 CET Mon Dec 3 2007
System image file is "flash:c2800nm-spservicesk9-mz.124-4.XC7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be
found at:
export@cisco.com.
Cisco 2821 (revision 53.51) with 237568K/24576K bytes of memory.
Processor board ID FHK0915F18G
2 Gigabit Ethernet interfaces
1 Serial interface
4 ISDN Basic Rate interfaces
1 terminal line
1 Channelized E1/PRI port
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
service password-encryption
tftp-server flash:P0030702T023.bin
tftp-server flash:P0030702T023.loads
tftp-server flash:P0030702T023.sb2
tftp-server flash:P0030702T023.sbn
tftp-server flash:P00405000700.bin
tftp-server flash:P00405000700.sbn
tftp-server flash:CP7912080001SCCP051117A.sbin
tftp-server flash:dsp11.1-0-0-73.sbn
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:Bass.raw
tftp-server flash:music-on-hold.au
tftp-server flash:apps11.1-0-0-72.sbn
tftp-server flash:cnu11.3-0-0-81.sbn
tftp-server flash:cvm11.7-2-0-66.sbn
tftp-server flash:jar11.7-2-0-66.sbn
tftp-server flash:SCCP11.7-2-1-0S.loads
tacacs-server administration
Hall of Fame Super Gold
Re: CME 4.0: 7940 displaying wrong time, 7911G displaying the ri
have you configured the correct time-zone under telephony service ?
Yes, timezone 26 has been configured.
Best Regards
Dirk
Have you configured summer-time ?
Can you try FW 8.0(7) on the 7940 ?
291
