Bronze
CME 4.0 and company logo
searching around, but no definite answer on this. can anyone assist? NOTE Call Manager Express
thanks
Hall of Fame Super Red
Re: CME 4.0 and company logo
Hi Arvind,
I have never tried this, but I think this might be what you are looking for in CME;
System Display Message (Idle URL) for the Cisco IP Phones 7940 and 7940G and Cisco IP Phones 7960 and 7960G
The system display message feature allows you to specify a file to display on Cisco IP Phones 7940 and 7940G and Cisco IP Phone 7960 and 7960G units when they are not in use. You can use this feature to provide the phone display with a system message that is refreshed at configurable intervals, similar to the way that the system text message feature provides a message. The difference between the two is that the system text message feature displays a single line of text at the bottom of the phone display, whereas the system display message feature can use the entire display area and contain graphic images.
To specify a system display message for idle phones, designate a URL that contains an XML file to be displayed on the Cisco IP phones that are not in use. You also specify the refresh interval for the display, in seconds. The file can contain text, icons, or images.
From this CME doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00804ad85d.html#wp2206032
Hope this helps!
Rob
Please remember to rate helpful posts.....
Bronze
Im thinking this is a bit different though. i know for a fact that if i go onto a CCM system and put the logo on, it stays there when i put it back on the CME system. however, i dont have the facility anymore to do that type of thing, plus this is a production evnironment and obviously not practical at all.
im sure there must be a way to do it
hey,
did u ever get the solution for this. I am in the same situation. the .xml works fine in CCM, but not in CME. I have used url idle with and without the .xml extension and it will not display
321
