03-15-2007 09:01 PM - edited 03-14-2019 08:30 PM
I'm having a problem with a 7914 expansion module attached to a 7960. There are 2 of these 7960's on the CME router, and my client wants both of these phones to have identical monitor extensions. I configured the first phone without any problems, but the 2nd phone is giving me fits! Every time I create a "monitor" extension in the GUI or the CLI, it ALWAYS defaults to "Normal Ring" instead of "monitor".
Is this happening because you cannot have two phones monitoring the same extension in CME 4.0?
03-16-2007 02:32 PM
I'm not aware of such a limitation. You may want to share some more config detail here, including FW for the phones, etc.
03-16-2007 02:36 PM
I found the issue: It's a bug with the CME GUI files. The workaround is to configure the monitor extensions manually and update the GUI files with the compatible version.
03-16-2007 02:39 PM
Very good. In fact you can find that is better to do most of the configuration manually not only because the too many limitation of the current GUI, but also because CLI is more powerful and direct.
