Community Member
CME 4.0 overlay not ringing phones
I have 6 phones with their main line being their DDI. The second line is
an overlay line. When the first call comes in phone A answers. When the second call comes into the same number the call only shows on phone A and doesn't ring on the other 5
phones. If I dial the number internally then the second call rings on the 5 phones.
IOS - 12.4(13r)T
Basically what I have is
ephone 2
mac-address xxxx.xxxx.xxxx
type 7965
button 1:2 2o23,26,27,28,29,30
ephone 3
type 7965
button 1:3 2o23,26,27,28,29,30
ephone 4
type 7965
button 1:4 2o23,26,27,28,29,30
ephone 5
type 7965
button 1:5 2o23,26,27,28,29,30
If anyone has any ideas it would be much appreciated.
Community Member
Re: CME 4.0 overlay not ringing phones
Can you provide the details of sh run, sh tech
Hall of Fame Super Gold
before CME 4.3, calls to a shared DN thta has a call active, rings only on the phone that has the first call.
The workaround is to set for the shared DN, "huntstop channel" and "call forward busy" in chain for all the shared DNs.
Note, you may want to use "c" and not "o" as button command, because that gives you audible call waiting tone, while "o" doesn't.
Community Member
I applied the huntstop channel command a few days ago and it sorted the problem. Forgot to update the post.
Thanks for the replys
You are welcome. Please rate useful posts with the scrollbox below.
210
