03-12-2007 02:19 AM - edited 03-14-2019 08:25 PM
Hello ,
I need to configure my cme 4.0 to send outgoing call throught different SIP provider .
I have already tryed with only 1 provider and all work fine .
Thanks .
03-12-2007 09:18 AM
Registration and making calls are two different things, you do not necessarily need to be registered to make outgoing calls.
Under "sip-ua", configure username/password/realm, and the router should use them in the authentication phase for each ITSP.
Please rate usful posts!
03-12-2007 09:56 AM
Hi ,
I have tried to configure another username and password , the system d'ont permit me and show the message "only one username are permit per device"
03-12-2007 11:04 AM
Standby, research in progress.
03-12-2007 09:52 PM
Ok, it seems to me that the current IOS is severely limited in this area:
1st, in "sip-ua" you can configure multiple (up to 5) password/realm combinations, but a single username. That means, if can have different ITSP to assign you the same authentication username, you can use multiple ITSP.
2nd, the authentication configuration in "dial-peer" mode, is available only for pots dial-peer, not voip. This appears like a bug in my opinion, or I would be very curious to know the reason why.
The above is actually documented at:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123tcr/123tvr/vrht_a1.htm#wp1613546
I've tried the configuration in sip-ua mode, as long the username is the same, you can actually configure multiple password/realm combinations. One final comment, the output from CLI on succesful configuration like Updating password for realm: xxx is really non-standard in IOS.
Hope this helps, if so, rate this post.
03-14-2007 01:58 AM
Hi ,
you tasks that the problem may be resolved upgrading the CME , now is ver. 4.0 (C2801-SPSERVICESK9-M), Version 12.4(9)T1 .
03-14-2007 10:17 AM
No, this limitation is not version dependent. I have a feeling it may be corrected in a future because it so absurd, However I have no basis to support my thinking.
Hope this helps, if so please rate post!
01-22-2008 07:43 AM
that doesn't look like a bug, but is reasonable:
authentication aids billing and CAC on provider side. If you could use authentication on voip dial-peers then the ip-device in your network using this dial-peer could authenticate itself the same way as a gateway in question. but if it is an analog or tdm device, it cannot do that so we have authentication only under pots dial-peers.
