Hello folks!
I try to use it but it doesnt work, in fact I do the follow steps and neither work:
For Windows 2000/XP:
From Control Panel execute the "Add/Remove Hardware" utility. Select
"Add/Troubleshoot" when the prompt "Choose a Hardware Task" is
displayed. Click the "Next" button. Select "Add a New Device" when
the prompt "Choose a Hardware Device" is displayed. Click the "Next"
button. Select "no" when the question "Do you want to search for new
hardware devices" is displayed. Click the "Next" button. Select
"Sound, video and game controller" when prompted for hardware type.
Click the "Next" button. Click the "Have Disk" button when prompted
to "Select a Device Driver". Click the "Browse" button on the
"Install from Disk" window. Browse to
C:\Program Files\Cisco\Wave Drivers and select the file "OEMSETUP".
Click "Open" to install the Cisco Wave Driver and select OK.
Highlight the "Cisco TAPI Wave Driver" in Select a Device Driver window
and select 'Next'
Select 'Next' in "Start Hardware Installation" window.
If Prompted for "Digital signature Not Found" select Yes and continue
install.
When prompted for "Install from disk 1" for file avaudio32.dll, choose
Browse button and select path "C:\Program Files\Cisco\Wave Drivers"
and click Open to install the avaudio32.dll.
When prompted to reboot your machine, do so.
Somebody has an idea?!
PLEASE HELP
