CME 4.1 and trunk config help
Hello, I'm building CME 4.1 on a 2851 to support 50 or so people at a remote office. I used QCT to set everything up, using mostly default values. I've got the system up and running for the most part, but I'm not sure if the switch trunks are configured correctly. Below are the router and corresponding switch interface configs...
***2851 router***
interface Loopback0
ip address 10.1.10.2 255.255.255.0
interface GigabitEthernet0/0
description ***switchport fa1/0/47***
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
interface Service-Engine0/0
ip unnumbered Loopback0
service-module ip address 10.1.10.1 255.255.255.0
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1
no ip address
no ip mroute-cache
duplex auto
speed auto
interface GigabitEthernet0/1.100
description ** Voice VLAN **
encapsulation dot1Q 100
service-policy output output-L3-to-L2
interface GigabitEthernet0/1.200
description ** Data VLAN **
encapsulation dot1Q 200 native
ip address 192.168.10.1 255.255.255.0
interface Serial0/0/0
no ip address
shutdown
ip route 10.1.10.1 255.255.255.255 Service-Engine0/0
***3750 switch***
interface FastEthernet1/0/47
description ***Gig0/0***
switchport access vlan 200
switchport trunk native vlan 100
switchport trunk allowed vlan 100
switchport mode trunk
switchport voice vlan 100
no snmp trap link-status
no mdix auto
spanning-tree portfast
interface FastEthernet1/0/48
description ***Gig0/1***
switchport trunk native vlan 200
no mdix auto
interface Vlan100
ip address 10.10.10.2 255.255.255.0
interface Vlan200
ip address 192.168.10.5 255.255.255.0
ip default-gateway 192.168.10.1
I had to change the SM on the Gig0/0 router interface to make it a 24bit to make it work (QCT configures 10.10.10.1 255.255.255.248, but that wouldn't let phones register even if I changed to vlan100 ip to match).
Any help/advice would be greatly appreciated!
Jad
Hall of Fame Super Gold
Re: CME 4.1 and trunk config help
this is wrong:
please remove all commands on 3750, just leave the defaults and it will work fine.
Thanks for the response --
do you really mean remove ALL commands? what about my VLAN's and switch IP's? Trunking?
...or do you mean remove all "switchport trunk native vlan 100" commands for all switchports? Please clarify.
Just leave "switchport mode trunk" and remove all the rest unde the relevant interface. Thats shoudl restablish connectivty to the phones. Then you can go from there.
sorry - can you show me an example of what you're trying to say?
under your trunk ports:
"no switchport access vlan 200"
and repeat for all the unnecessary commands you have. The only needed one is "switchport mode trunk".
that doesn't work - and the reason why i'm confused. If i pull those commands off, i don't get voice or data on any ports and lose all ping communications between the switch and the router.
If I add "switchport trunk native vlan 200" to int fa48, the trunk is built. Adding "switchport trunk native vlan 100" to fa47 gets voice traffic working. I can't see how it would work any other way.
Ok, I see. You just want one port of 3845 do voice, and other do data. Then, on router, remove subinterfaces and configure ip directly on main interfaces.
On the switch, configure "switchport mode access" and "switchport access vlan xx". Do not worry if no vlan is marked voice - that won't make any difference, and you can still configure as "voice vlan" on ports connected to telephones.
247
