CME 4.1 don't get call-forward night-service to work
Hi all,
I try to get call-forward night-service to work. I did setup night-service as described by the Cisco Unified Communications Manager Express System Administrator Guide.
telephony-service
night-service code *1234
night-service day Sun 18:01 07:59
night-service day Mon 18:01 07:59
night-service day Tue 18:01 07:59
night-service day Wed 18:01 07:59
night-service day Thu 18:01 07:59
night-service day Fri 18:01 18:00
night-service day Sat 18:01 18:00
ephone-dn 20 dual-line
number 10
call-forward all 20
call-forward night-service 30
huntstop channel
All calles to 10 are forwarded to 20 at anytime.
Does someone have an idea why this doesn't work?
IOS Version: 12.4(11)XJ2
CME: 4.1
Best regards
Sven.
Hall of Fame Super Red
Re: CME 4.1 don't get call-forward night-service to work
Hi Sven,
You must also configure the night-service bell command for this ephone-dn.
Night-service hours are defined using the night-service date and night-service day commands.
An ephone-dn can have all four types of call forwarding defined at the same time: all-calls, no-answer, busy, and night-service. Each type of call forwarding can have a different forwarding destination defined in its target-number argument. If more than one type of call forwarding is in effect (is active) at one time, the precedence order for evaluating the different types is as follows:
1. call forward night-service
2. call forward all
3. call forward busy and call forward no answer
If you use an ephone-dn template to apply a command to an ephone-dn and you also use the same command in ephone-dn configuration mode for the same ephone-dn, the value that you set in ephone-dn configuration mode has priority.
number 10
call-forward all 20
night-service bell
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_command_reference_chapter09186a008061134b.html#wp1063536
Hope this helps!
Rob
Hi Rob,
Many thanks. This resolved my issue.
Thx
Sven.
758
