Community Member
CME 4.1 issue
I have an issue when i take a phone off hook i get a busy signal. I am sure it is something simple, but until i figure it out i am stuck. The phone generates the following error on the CME router:
*Sep 26 02:28:08.243: %CALL_CONTROL-6-APP_NOT_FOUND: Application telephony-service in dial-peer 20001 not found. Handing callid 5 to the alternate app .
I am assuming something with dial-peer configuration but cannot seem to get it resolve. Thanks in advance.
1 ACCEPTED SOLUTION
Re: CME 4.1 issue
I'm not sure what could cause this problem - not familiar with this error message. You could start with removing telephony-service and ephone/ephone-dn, and re-adding. As well, a reload of the gateway.
-nick
Re: CME 4.1 issue
Which IOS version are you on?
Community Member
Re: CME 4.1 issue
12.4.15T
Re: CME 4.1 issue
-nick
Community Member
Re: CME 4.1 issue
i reinstalled CME from scratch and loading a config i knew worked. It ran fine after that. Not sure what was wrong, (i.e bad CME install or bad config) but either way functioning fine. THanks
256
