Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CME 4.1 Not ready on ephone-hunt
Can a dn log in or out of a hunt list in 4.1? Is there anything similar to not ready for this version?
Hall of Fame Super Gold
Re: CME 4.1 Not ready on ephone-hunt
Yes, refer to documentation.
You presume I haven't?
If it IS there I have obviously missed or not understood it. This post was a last resort, but if the solution is to re-read it that is what I will do.
I guess confirming that there IS a solution for cme 4.1 is helpful. Thanks
Since there are multiple ways to do that, and the documentation does a better job at explaining these than myself in this space, that is why I recommend you read it. On the other hand I have no way of knowing if you did that already, but know for sure that many people do not.
Hall of Fame Super Red
Hi Matthew,
Just to add a note to the great info from my friend Paolo,
hunt-group  logout
To  enable separate handling of DND and HLog functionality for hunt-group  agents and to display the HLog soft key on phones, use the hunt-group  logout command in telephony-service configuration mode. To return to the  default, use the no form of this command.
hunt-group logout [DND | HLog]
no  hunt-group logout [DND | HLog]
Syntax Description
DND
Agent  phones do not answer the number of calls specified in the auto logout  command and are automatically placed in both DND status and not-ready  status. The HLog soft key is not displayed on phones.
HLog
Agent phones do not answer the number of calls specified in the auto  logout command and are automatically placed only in not-ready status.  The HLog soft key is displayed on phones in addition to the DND soft  key.
Examples
The  following example creates hunt group 3 with three agents (extensions  1001, 1002, and 1003). It specifies that after one unanswered call, an  agent should be put into not-ready status but not into DND status.
Router(config)#  telephony-service
Router(config-telephony)# hunt-group logout HLog
Router(config-telephony)#  exit
Router(config)#  ephone-hunt 3 peer
Router(config-ephone-hunt)# pilot 4200
Router(config-ephone-hunt)#  list 1001, 1002, 1003
Router(config-ephone-hunt)# timeout 10
Router(config-ephone-hunt)#  auto logout
Router(config-ephone-hunt)#  final 4500
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_h1ht.html#wp1013940
auto logout
To enable  the automatic change of an ephone hunt group agent's ephone-dn to  not-ready status after a specified number of hunt-group calls are not  answered, use the auto logout command in ephone-hunt configuration mode.  To disable automatic logout, use the no form of this command.
auto logout  [number-of-calls] [dynamic | static]
no auto logout [number-of-calls]  [dynamic | static]
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_a1ht.html#wp1012834
Hope this  helps!
Rob
569
