CME 4.1 to CUE MWI issues
I am having a heck of a time getting MWI to work on a 2811 with CUE. Running CME 4.1 and voice mail works (pilot #) and I can leave msg but no MWI. Right now when I dial the 4-digit MWI on dn I get a busy. Any help would be appreciated.
The ephone-dn(s) i have now when I get the busy are;
ephone-dn 118
number 9897....
description VoiceMail CUE MWI On
mwi on
ephone-dn 119
number 9898....
description VoiceMail CUE MWI Off
mwi off
If i configure these without the .... I get the MWI to light but the phone continues to ring. When I hit end call the MWI is lit.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CME 4.1 to CUE MWI issues
Hi Johnny,
The number of dots (...) should be equal to the extension length being used :)
Have a look at this excellent Troubleshooting doc;
Troubleshooting Unity Express Message Waiting Indication (MWI) Problems
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a008027fa9f.shtml
Hope this helps!
Rob
Hi Johnny,
Hope this helps!
Rob
I ended up rebooting everything and it worked. Thanks for the suggestion.
253
