Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CME 4.1 & Translation Profile
Please Help. I have a CME 4.1 and the below translation profile with rules. I am tring to get the thing to take any called number coming to me on the SIP trunk to translate any extension that begins with 9 and change it to a 3. So xxx xxx 9xxx would be xxx xxx 3xxx and then send it to the CME. For some reason it won't allow the call down. Of course, when the user calls out, and it changes it to a 9 (supposedly) the call goes out pots.
Anyone... Please help!
voice translation-profile Incoming_Change_93
translate called 5
voice translation-rule 5
rule 1 /^2142909\(...$\)/ /2142903\1/
voice translation-profile Outgoing_Change_39
translate called 6
voice translation-rule 6
rule 1 /3.../ /2142909\1/
Hall of Fame Super Gold
Re: CME 4.1 & Translation Profile
You need to apply the translation-profile into the relevant DP. Note rule 5 can be written more concisely as:
rule 1 /^2142909/ /2142903/
Aye, I applied it, but does CME change these for outgoing SIP VOIP peers? it doesn't do right.
What about the outgoing? from 3... to the /3.../ /214290\(9...)/ ? That doesn't seem to work on outgoing and the SIP trunk rejects it...
Thanks again for your help!
Please note that I am changing it from a 2142909... to the internal extension and ringing the user at 3...
All what matter is that you have the profile applied to the right DP. That you may have missed. Your need is done with:
rule 1 /^2142909/ /3/
Yeah. But when I send the call up the SIP, it needs to go back from 3... to the 2142909....
That is where the trick comes in, I believe.
Can anyone help me translate this from a 3... to a 2142909... ?
Thanks.
137
