CME 4.1 - voice translation-rule
abartolomeu
Hi!
A voice translation-rule only allows 15 rules. I need more! Do you have any useful advice to solve this?
Ana
5 Replies 5
Marwan ALshawi
it is limited to 15 !!
but let me know what is ur goal maybe we can find a work around :)
good luck
The client has 3 ranges of DDIs. He wants phone extensions to correspond to the floor and room where the phone is (example Floor 4, room 1 ->401). What I have now is:
voice translation-rule 1
rule 1 /257/ /510/
rule 2 /267/ /610/
rule 3 /667/ /609/
rule 4 /268/ /611/
rule 5 /347/ /711/
rule 6 /269/ /511/
rule 7 /668/ /402/
rule 8 /250/ /750/
rule 9 /660/ /750/
rule 10 /669/ /710/
rule 11 /^25/ /50/
rule 12 /^26/ /60/
rule 13 /^66/ /70/
I need to configure more extensions on the 4th floor.
u can acieve it in diffrent way
let say phone 510 has ptsn number as 123257
make like
ephone-dn 1 dual-line
number 510 secondary 123257
any call ring any number from the above will ring dn 1
and u can configure all phones like this and u dont need any dial-paln under telephny service remove it in this case if u have it
for more details i had addressed an issue exactly like urs at the foolowing link:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc18628/7#selected_message
good luck
if helpful rate
I will do as you say.
Thank you very much for your help!
Ana
but follow the configs on the link
and let me know
good luck
