CME 4.2 off-hook hand-set does not work
Sometimes making off-hook does not work
You must press answer button explicitly
I observe this 7911, 7945 ,,,
Are there any solution?
Re: CME 4.2 off-hook hand-set does not work
We get this a lot
Just key Settings then **#**
This will reset the phone till the next time.
Not aware of a permanent fix for this
Try configuring "auto-line incoming" under the ephones in question. This should remedy your issue.
Hope that helps, if so please rate post.
We have exactly the same problem on CallManager (not express). Is there a "auto-line incoming" equivalent int CCM?
Resetting the phone will not satisfy our costumer..
Is there a bugID for this issue?
Thanks a lot,
Kind regards,
Gert-Jan
Hall of Fame Super Red
Hi Gert-Jan,
I'm 99% sure its RMA time for these phones. This is most likely a problem with the Hookswitch. After deploying Cisco IP Phones for the last few years we (and many others) have found this to be the most common hardware problem.
There is a "Best Practice" for cleaning the Hookswitch contacts (link below) that does work on occasion. Usually the phone has to be replaced/RMA'd.
Best?? Practices for Cleaning and Troubleshooting Cisco IP Phone Hookswitch
From this interesting Tech note;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a00801c0810.shtml
There was also a problem with the 7.2 phone firmware that caused similar looking symptoms for the 3rd generation phones like the 7970/7961/7941. This could be rectified in the short term by booting the phone. If your issue can be fixed by resetting the phone and you are running 7.2 firmware, let me know and I will find you the Bug.
Hope this helps!
Rob
177
