02-27-2012 06:59 AM - edited 03-16-2019 09:48 AM
I've couple of cme verison 4.2 and c2821 routers.
I'll upgrade cme 8.6.
I used to cme 4.2 service aaa configration.
application
service queue flash:app-b-acd-2.1.2.2.tcl
param aa-hunt3 7710
param queue-len 10
param aa-hunt5 7700
param aa-hunt1 7750
param aa-hunt2 7720
param number-of-hunt-grps 9
param queue-manager-debugs 1
service aa flash:app-b-acd-aa-2.1.2.2.tcl
param number-of-hunt-grps 4
paramspace english index 1
param menu-timeout 1
param handoff-string aa
param dial-by-extension-option 4
paramspace english language en
param max-time-vm-retry 2
param max-extension-length 4
param aa-pilot 7810
paramspace english location flash:
param second-greeting-time 20
param welcome-prompt _bacd_welcome.au
param call-retry-timer 15
param max-time-call-retry 600
param voice-mail 7700
param service-name queue
group-params aa-hunt2
group-params aa-hunt3
group-params param
group-params aa-hunt1
group-params aa-hunt5
interface Loopback0
ip address 5.5.5.5 255.255.255.255
dial-peer voice 7810 voip
service aa
destination-pattern 7810
monitor probe icmp-ping
session target ipv4:5.5.5.5
incoming called-number 7810
dtmf-relay rtp-nte digit-drop h245-alphanumeric cisco-rtp h245-signal
codec g711ulaw
voice-port 0/1/1
supervisory disconnect dualtone mid-call
output attenuation 1
timeouts call-disconnect 5
timeouts ringing 60
timeouts wait-release 1
timing hookflash-out 50
timing sup-disconnect 1000
connection plar opx 7810
caller-id enable
I can try this configration for c2800nm-ipvoice-mz.151-2.T1.bin software but service aa apllication is not runing.
I thnik so I want to need migration document or migration tool.
Can you help me?
Solved! Go to Solution.
02-27-2012 07:08 AM
Something is missing or not configured right, because it should work the same.
02-27-2012 08:52 AM
There is no such document.
It's supposed to work the same, as mentioned before. IF it doesn't, you need to troubleshoot why.
02-27-2012 07:08 AM
02-27-2012 08:16 AM
I can try same configrations. I can use 3 diffrent router but still not working.
I think so I want to need cme 8 application documents.
02-27-2012 08:52 AM
