CME 7.0(1) and ephone-hunt: no ring on one extension
raziel78kain
Level 2
Level 2
Hello.
We have a CME 7.0(1) with an ephone-hunt configured in this way:
ephone-hunt 1 longest-idle
pilot 999
list 300, 308, 309, 313, 306, 303, 307, 310
final 399
timeout 8, 8, 8, 8, 8, 8, 8, 8
statistics collect
The problem is that one of the extensions (308) never rings.
The strange thing is that, if we issue the command "show ephone-hunt 1", we see:
Group 1
    type: longest-idle
    pilot number: 999, peer-tag 20105
    list of numbers:
        300, aux-number A999A0000, # peers 1, logout 0, down 0
            on-hook time stamp 132961644, off-hook agents=0
            peer-tag  dn-tag  rna  login/logout  up/down
             [20104     13     0       login      up  ]
        308, aux-number A999A0001, # peers 1, logout 0, down 0
            on-hook time stamp 132817384, off-hook agents=-1
             [20106     16     0       login      up  ]
        309, aux-number A999A0002, # peers 1, logout 0, down 0
            on-hook time stamp 132967204, off-hook agents=0
             [20107     18     0       login      up  ]
        313, aux-number A999A0003, # peers 1, logout 0, down 0
            on-hook time stamp 132961535, off-hook agents=0
             [20108     20     0       login      up  ]
        306, aux-number A999A0004, # peers 1, logout 0, down 0
            on-hook time stamp 132870090, off-hook agents=0
             [20109     14     0       login      up  ]
        303, aux-number A999A0005, # peers 1, logout 0, down 0
            on-hook time stamp 132969444, off-hook agents=0
             [20110     19     0       login      up  ]
        307, aux-number A999A0006, # peers 1, logout 0, down 0
            on-hook time stamp 132934257, off-hook agents=0
             [20111     17     0       login      up  ]
        310, aux-number A999A0007, # peers 1, logout 0, down 0
            on-hook time stamp 132817384, off-hook agents=0
             [20112     15     0       login      up  ]
    final number: 399
    preference: 0
    preference (sec): 7
    timeout: 8, 8, 8, 8, 8, 8, 8, 8
    hops: 8
    E.164 register: yes
    auto logout: no
    stat collect: yes
    callqueue display: continuously
    debug: no
What does "off-hook agents=-1" mean?
We have understood the meaning of "off-hook agents=0" and "off-hook agents=1", but with "-1"...?
Could be that the problem? How could we fix that?
Thanks for your help and regards.
Did you fix this issue.
Please  help.
thanks
vijay
Dear Vijay,
we have solved the problem.
It seems that, when we configure the ephone-hunt, the phones must be in idle state (no conversation must be in progress) and haven't to be in DND state.
Regards.
