CME 7.0 unassigned number (1) NEED HELP ASAP PLZ!!!!!
Just ported few DID's over and all the new ported DID's are failing with unassigned number (1).. The provider is saying they're sending the calls the same way the initial DID is routed, but for some reason all the ported numbers are failing except for the one.. I did a translation-rule but that didn't help..
Someone out these can assist asap please ?
This is the logg from not working numbers:
.Jun 14 18:58:22.876: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId BFA3ECD0B58911E18741B24AFB322129, SetupTime .14:58:22.826 pst Thu Jun 14 2012, PeerAddres
+13475780000, PeerSubAddress , DisconnectCause 1   , DisconnectText unassigned number (1), ConnectTime .14:58:22.876 pst Thu Jun 14 2012, DisconnectTime .14:58:22.876 p
t Thu Jun 14 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
.Jun 14 18:58:22.876: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/14/2012 14:58:22.828,cgn:+13475784202,cdn:718621800,frs:0,fid:556,fcid:BFA3ECD0B58911E18741B24
FB322129,legID:1B9,bguid:BFA3ECD0B58911E18741B24AFB322129
.Jun 14 18:58:22.876: //441/BFA3ECD08741/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x68BE2420
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : +13475784000
Called Number            : 718600000
Source IP Address (Sig  ): 108.170.00.00
Destn SIP Req Addr:Port  : 64.154.00.100:5060
Destn SIP Resp Addr:Port : 64.154.00.100:5060
Destination Name         : 64.154.41.000
.Jun 14 18:58:22.876: //441/BFA3ECD08741/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g729r8
Negotiated Codec Bytes   : 20
Nego. Codec payload      : 18 (tx), 18 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 108.170.99.00
Source IP Port    (Media): 16936
Destn  IP Address (Media): 64.154.41.001
Destn  IP Port    (Media): 33678
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 1
Disconnect Cause (SIP)   : 404
1 REPLY
Never mind I got it working.. Thanks for nothing cisco board!!!
717
