CME 7.1 not able to add new user
HI,
In CME 7.1 i can via gui the max number of limit for users is 200 but when i see data sheet for CME 7.1 with cisco 3845 it shows it support 250 ip phones.
My question is why the limit for user is 200
thanks
1 REPLY
Green
Asim,
You may be hitting this bug
CSCtd35866
CME 7.1 GUI doesn't shows the ephone with ID beyond the "max-ephones"
Symptom:
If customer configure the Max-ephone 100 under Telephony-system, the CME GUI only shows the ephone with ID that below 100. The CME GUI does not shows any ephone with ID that above 100.
Notes, the ephone ID is not relevant with max-ephones configuration. Customer can assign any ID to ephone. The "max ephones" command should only limited the max ephone can be registered to the system.
Conditions:
Environment:
CME: 7.1
GUI: 7.1
Workaround:
Ensure the ephone ID is smaller than the value be configured in "max-ephones".
Details
Known Affected Releases: (1)
12.4(22)T
Known Fixed Releases: 0
No release planned to fix this bug
Product: Cisco Unified Communications Manager Express
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
112
