CME & 7925 wifi-phone
Epic200988
Just got new model of phones and it appears the CME doesn't have a config for the phones when i attempt to add them to CME as a type 7925.
Do i need to get new code for the router? It's also the vpn connection etc. Will this cause a down time if i do need to to add new code to the router or can i say the 7925 is the same model as a 7921???
Thanks!
Epic200988
Assuming i need this??
Cisco Unified Wireless IP Phone 7925G Firmware + Java AOM files - Compatible CCME Versions 4.3 and later
cmterm-7925-sccp.1-4-2.zip Cisco Unified Wireless IP Phone 7925G Firmware + Java AOM files - Compatible CCME Versions 4.3 and later
My CME ver is 12.4(15)T3
Hi Mitch,
CMe supports the 7925 phones:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme71spc.htm
You need to download the firmware on your router from:
http://www.cisco.com/cisco/software/release.html?mdfid=282359287&catid=278875240&softwareid=282074289&release=1.4(2)&relind=AVAILABLE&rellifecycle=&reltype=latest
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
testeven,
I got the firmware downloaded to flash on CME. I can't find any documentation that states i need to do more configuration to the router for the phone type to show up.
Any idea?
You need to update IOS.
