Community Member
CME 7940 directory and ntp-server params not exported
I have running config:
voice register global
mode cme
source-address X.X.X.X port 5060
max-dn 144
max-pool 42
load 7960-7940 P0S3-08-8-00
authenticate register
authenticate realm sip.example.com
timezone 32
time-format 24
url directory http://dir.example.com/directory.xml
tftp-path flash:
create profile sync 0248402420004889
ntp-server X.X.X.X mode unicast
But it's seems IOS don't care about 7940-7960 type phones and don't generate corresponding fields in corresponding CNF files. I don't see problem with 7911 phones.
Running on c2800nm-advipservicesk9-mz.124-15.T4
Hall of Fame Super Gold
Re: CME 7940 directory and ntp-server params not exported
Hi, I don't want to sound bitter, but this is exactly the kind of problems that you meet using cisco phones in SIP: "doesn't do this, that doesn't work".
This is why the preferred mode is SCCP. All the features, none of the hassle.
Community Member
Partially agree with you paolo. I was still get more issues with SCCP than SIP, like one-way sound issue and dropping calls and SCCP almost not workable in NAT environment.
And that's not big issue after all, because there are workaround - manually edit file. But definitely agree with you Cisco should put more hands on SIP part.
Basicly Cisco itself create more RFC related to SIP than any others so that's make no sense, doing lossy product after all.
Even if router/pix claims support for nat and sccp, in reality it was never thought as a nattable protocol. What most people do, use VPN and end of history.
Wrt to SIP and cisco, one thing is having good engineers (not necessarily CM or CME engineers) writing rfc's, another one is having other (possibly different) good engineers to make products that work, are quite advanced, and why not, a little proprietary too. That is, the definition of cisco's approach to IPT.
Community Member
I never expect SCCP to work well under NAT. VPN is ONLY solution but this "not works" for us.
Why I'm still rely on SIP because of heavy using third party phone like Nokia E series. Well we can use both SCCP and SIP but I can't managed to get this work property, just creates more problems than its solves.
Thanks anyway for your help!
211
