CME 79XX Web Access Enabled = No
How can I change the handset Web Access Enabled to YES with CME7.1 ?
  • IP Telephony
1 ACCEPTED SOLUTION
Super Bronze
Re: CME 79XX Web Access Enabled = No
Good to hear..
Please help to identify useful content in the forums by marking questions as 'answered' if you have received a suitable response..
https://supportforums.cisco.com/docs/DOC-6212
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
You can enable this for all phones like as follows (this will just insert the webAccess parameter into the vendor specific section of the XML config file the phones load as they boot - the webAccess bit will be case sensitive).
Telephony-service
Service phone webAccess 1
Create cnf-files
Then restart your phones...
Aaron
Please rate helpful posts...
Yes, that work correctly.
Super Bronze
Good to hear..
Aaron
CME version 7.0.0
Had to change "service phone webAccess" value to "0" so = enable. "1" = disable.
Tested with "1" and it was disable on phones 7960 and 7962. Tried with latest firmware also (7960 at 8.1.2) (7962 at 9.0.2).
I have CME versin 8.8,
I have CME versin 8.8, "service phone webAccess=0" command enabled Web Access, but 1 disables it.
6510
