CME 8.0 and IP phone 7962G hardware rev 16.0 compatibility issue
Dear Experts,
One of my customers is using UC560 (uc500-advipservicesk9-mz.150-1.XA), CME version 8.0 with IP phone 7962G (hardware revision 16.0).
The firmware I used for the "load" and "tftp-server" command was "load 7962 SCCP42.9-3-1SR1-1S" (9.3(1)SR1), since I followed the following document:
The hardware updates improve the compatibility of internal phone components.
The following table lists the updated hardware versions that require this release.
Phone
Hardware Version
Cisco Unified IP Phone 7942G
15.0 and higher
Cisco Unified IP Phone 7962G
15.0 and higher
Cisco Unified IP Phone 7945G
13.0 and higher
Cisco Unified IP Phone 7965G
13.0 and higher
Cisco Unified IP Phone 7975G
12.0 and higher
Phones manufactured with these hardware versions must run Firmware  Release 9.3(1)SR1 or later. The phone firmware does not allow the phone  to be downgraded to releases earlier than Release 9.3(1)SR1.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7900_series/firmware/9_3_1SR1/release_notes/P790_BK_R4E1E768_00_rn-9_3_1_sr1-7900-series_chapter_00.html#P790_RF_ND56648A_00
The issue is that at the moment, whenever I need to make simple changes on the phones, i.e. changing names displayed, I have to factory reset the phone for it to take effect, as the phone is not able to register if I soft reset it.
Could it be due to compatibility issue with the phone firmware? Since I noticed that CME 8.0 listed "SCCP42.8-5-3S.loads" as the supported firmware for 7962G?
If it's the issue, then what do I need to do to rectify it? Upgrade the UC560? If so, to which version?
Your support would be greatly appreciated.
Thanks and regards,
Nhan.
Hall of Fame Super Silver
If you do not want ti upgrade your CME, then simply upgrade the firmware load for the phone type, and reference it under tftp.
HTH,
Chris
Hi Chris,
Thanks for your answer. However, does upgrade the phone firmware to higher versions solve the issue? Since any phone firmware versions that are higher than 8.5(3) are not listed as supported by CME 8.0 anyway.
Thanks and Regards,
Nhan.
Yes, it will solve the problem, any firmware works just fine with any CME version.
Chris
200
