Community Member
CME 8.0/CUE & Automated Attendent
I am looking for some help on setting up a Automated Attendent on CME & CUE.
I have configured the dial-peer with the pilot number and used the GUI on CUE for setting up the prompts.
I am confused on what else needs done. I am looking for a guide on the complete process of setting an AA up and help working through my configuration.
2 ACCEPTED SOLUTIONS
Re: CME 8.0/CUE & Automated Attendent
You would like to check this link too:
http://tools.cisco.com/support/downloads/pub/Model.x?mdfid=282935847&mdfLevel=Software%20Version/Option&treeName=Voice%20and%20Unified%20Communications&modelName=Cisco%20Unity%20Express%20Version%208.0&treeMdfId=278875240
In the Unity Express Utilities you can download de CUE Editor so you can create your scripts, and also you can find some example scripts.
Gabriel.
Joe,
Take a look here: http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a00803f82eb.shtml
The guide is a little older but the menus likely are very close.  You may also look for the 8.0 version-specific guide on Cisco.
Hailey
Please rate helpful posts!
Gabriel.
235
