CME 8.6 aa not working
VelocityCS
Hi all
I've spent cumulatively about 5 hours on this now (including googling) so got to the stage where I need to ask your advice
Very simple requirement: Single aa, drop-through mode to an ephone hunt-group
Problem is, it's not working
Details:
1 - Dial Peer
dial-peer voice 4333 pots
service app-b-acd-aa
incoming called-number 4333
! I have also tried the full 01234884333 and 1234884333 with similar problem
port 0/0/0:15
! This is the correct port for my CME
2 - Hunt Group
ephone-hunt 2 longest-idle
pilot 5001
list 4334
statistics collect
3 - Queue
service app-b-acd
param queue-len 15
param number-of-hunt-grps 1
param aa-hunt1 5001
! Single hunt group - same ext as the Hunt Group above
param queue-manager-debugs 1
4 - AA
paramspace english index 1
paramspace english language en
paramspace english location flash0:/cme-b-acd-2.1.2.3/
! This is the correct path to the .au files
param second-greeting-time 60
param max-time-call-retry 700
param call-retry-timer 15
param aa-pilot 4333
! As in the dial-peer, I have tried the extn as well as the full number
param handoff-string app-b-acd-aa
param service-name app-b-acd
I'm in the UK, so phone numbers are in the format 01234 567890. However, due to whatever, they are presented at the CME as 1234 567890 - the leading 0 is dropped at the exchange
When I add a dial-peer, I typically add just the 4 digit extension
What happens:
Dial the hunt-group target (4334) - phone rings fine
Dial the hunt group (5001) - rings fine
Dial the aa pilot (4333) and it disconnects instantly
Dial the full number (01234884333) and I get automated BT woman "The other person has hung up"
This is driving me nuts - something which should be so straighforward, so if anyone can point out where I've been stupid, I'd really appreciate it
Thanks in advance
Hi Wayne,
Its great to hear that all is working fine now.
and it's up to you.
Nart
10 Replies 10
Kevin Monteiro
Level 7
Level 7
You need a destination-pattern in your pots dial-peer and not a incoming called number.
Try the change.
Rate the post accordingly.
Kevin
Sent from Cisco Technical Support Android App
Hi Kevin
I tried that, adding the destination-pattern both as the 4 figure extn, the full number, and as the number with the leading 0 taken off - still no joy. I then tried the same after pulling the incoming called-number. Full number with/without the leading 0 I just get error tones. Extension only I go back to "other person has hung up"
nomat
Hi Wayne,
Looking at your config, I see that you are missing the voicemail parameter in the aa service, add it and test.
Also, make sure that you have music on hold configured on the CME.
you can use the "debug voice application error" to see what is going on if the above doesn't work.
Have a look at the example in the link below, you can copy it and modify it to your needs:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/bacd/configuration/guide/cme40tcl/40bacd.html#wp1003141
Let me know how it goes.
Nart
CCIE voice
Hi Nart
I dont actually want voicemail on this - they'll all get answered eventually
Hi Wayne,
You can put the VM parameter to point to any number, you can even use the hunt group number or another group.
This is a mandatory parameter and it has to be there, similar to MOH.
Please see step 31 in the link below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/bacd/configuration/guide/cme40tcl/40bacd.html#wp1025932
Nart
Wayne,
Remove the port number "0/0/0:15", see if that works.
port 0/0/0:15
You are using a drop through mode however drop through option "Parameter" is missing in the config
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
VelocityCS
Okay, thanks all, it's now working. Really appreciate the swift help
Details:
1 - Dial Peer
destination-pattern 01234884333
! Thanks Kevin for this. It also needed the full UK number, not just the 4 digit extn
port 0/0/0:15
2 - Hunt Group
pilot 5001
list 4334
statistics collect
! This was all correct
3 - Queue
service app-b-acd
param queue-len 15
param aa-hunt1 5001
4 - AA
param aa-pilot 4333
param voice-mail 7777
! Thanks Nart, didn't notice this was mandatory
param drop-through-option 1
! Thanks Nadeem, from the doc this appeared to be optional if you had already specified a single number-of-hunt-grps
param drop-through-prompt _bacd_welcome.au
Not sure which post to mark as Correct Answer since it was a combination, any preferences guys?
Hi Wayne,
and it's up to you.
Nart
Kevin Monteiro
Level 7
Level 7
Glad everyone was able to help .(+ 5 )for Nart and Nadeem. great going Guys!!
