04-16-2012 11:10 PM - edited 03-16-2019 10:41 AM
Please let me know what are the basic command to enable AUTO-Register SCCP IP Phone in CME 8.6 in the DN range 3XX ?
04-16-2012 11:20 PM
Bala,
Following document has a commands/ procedure to block auto-reg, so negation of that command should help you achieve what you want. Also I believe auto-reg is enabled by default in CME.
GP.
Pls rate helpful posts !!
04-16-2012 11:42 PM
Thanks for the reply, how to mention the DN ranges for auto registration?
04-17-2012 12:17 AM
After enabling auto-reg, the DN range can be specified by command " Auto ". Syntax could be "Auto 3000-3400 ".
GP.
04-17-2012 12:27 AM
Hi Bala,
Under telephony-service you can give the command "auto-assign
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_a1ht.html#wp1117687
please rate helpful posts!!!
Abdul Sattar
04-17-2012 01:03 AM
If we have 350 end point and the internal number start from 3000 to 3250, in this case we need to manualy confiure 350 ephone-dn and then use auto-asign 1 to 350.
Is there is any way to specifiy the dn range and allow CME to auto register ?
04-17-2012 08:29 AM
Enable auto-registration using the command auto-reg-ephone, you don't need to manually configure any DNs
Your question about how to specify a range has already been answered by Abdul, you can refer to the command reference guide if you need more help, but he's telling you exactly how to enter the command to specify the DN range to be used.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesky
