CME 8.6 Auto registering IP Phone
Please let me know what are the basic command to enable AUTO-Register SCCP IP Phone in CME 8.6 in the DN range 3XX  ?
Bala,
Following document has a commands/ procedure to block auto-reg, so negation of that command should help you achieve what you want. Also I believe auto-reg is enabled by default in CME.
Checkout http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesystm.html#wp1019342
GP.
Pls rate helpful posts !!
Thanks for the reply, how to mention the DN ranges for auto registration?
After enabling auto-reg, the DN range can be specified by command " Auto ". Syntax could be "Auto 3000-3400 ".
GP.
Hi Bala,
            Under telephony-service you can give the command "auto-assign to "  , here the range that you are giving should be already configured for ephone-dns.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_a1ht.html#wp1117687
please rate helpful posts!!!
Abdul Sattar
If we have 350 end point and  the internal number start from 3000 to 3250, in this case we need to manualy confiure 350 ephone-dn and then use auto-asign 1 to 350.
Is there is any way to specifiy the dn range and allow CME to auto register ?
Enable auto-registration using the command auto-reg-ephone, you don't need to manually configure any DNs
Your question about how to specify a range has already been answered by Abdul, you can refer to the command reference guide if you need more help, but he's telling you exactly how to enter the command to specify the DN range to be used.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesky
java
if this helps, please rate
1353
