CME 8.6 Call Disconnect Issue
Hi All -
My company has a small CME deployment in Australia and yesterday the local network resource made some changes to the network related to other work but following their changes, a very weird problem is occuring on the system.
The site has 4 POTS lines coming in on a VIC-4FXO card and when calls come in, the IP phones ring but as soon as they try to answer the call disconnects. I was suspecting a codec negotiation issue but since the call is coming from the PSTN, I'm not real sure because it should be G.711 which the IP phones should handle fine.
my ccapi debugs show the call disconnecting with the typical 16 cause code (normal clearing). I can provide any part of the config or debug output required for some ideas.....
I appreciate the help.
Tom
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
try
voice-port 0/x/y
no battery-reversal
try
voice-port 0/x/y
no battery-reversal
AMAZING! Worked like a charm. Thanks so much for your quick reply.
Any idea what would cause this would happen. I'm looking at an old archived config and the command "no battery-reversal" was not under the voice-port.
Re: CME 8.6 Call Disconnect Issue
Sometime telco do things and one doesn't even know why. Anyway, is better to have it, that not.
Thank you for the nice rating and good look!
Hey Paolo,
I am facing the same issue but only with a single user.
Using ISDN2e (bri). She answers the call and it disconnects, can you please shine some light please
Please rate the post
Shibly Ibrahim
Please rate the post Shibly Ibrahim
457
