CME 8.6 call routing based on time
In CME 8.6, non-office hours end users call should be forward to the mobile number.
In Holidays all the calls should be forwared to remote destination, In CME 8.6 it is poosible call routing based on time and Holiday ?
1 ACCEPTED SOLUTION
Re: CME 8.6 call routing based on time
You should change the call flow a bit, create an ephone-dn which call forward all to hunt group 800. Then use night service in this ephone-dn.
HTH,
Alex
*Please rate helpful posts
Hall of Fame Super Silver
You can use nigh-service feature, quick search of this forum locates many good threads, here is a document I found:
https://supportforums.cisco.com/docs/DOC-1170
You can also reference the Admin Guide for more details.
As to holiday schedule you could route the call thorough the voicemail system (CUE, UCON, etc) which can define Holidays.
HTH,
Chris
Hall of Fame Super Gold
In addition to the great answer given above (+5 to Chris), in case you do not have a do not want CUE, you can use my B-ACD/AA modification (available at ciscoscripts.com) to achieve this requirement.
One more requirement from customer as below:
ephone-hunt 1 longest-idle
pilot 800
list 807, 808, 809, 810
final 777
This for a small callcentre setup, in office hours the call should be with the list number, in non-office hours the call should be forward to head office call centre number. Please light me how to use nigh-service feature in ephone-hunt.
HTH,
Alex
Excellent answer from Alex hat I've rated as well!
I am glad it helped and thank you both for the nice rating!
Best regards,
Alex
707
