CME 8.6 Inbound SIP Oddities
Hi everyone,
I have a cisco 3825 running 15.1(3) with CME 8.6. I have a sip trunk registered to a voip.ms SIP account and 2 voip.ms DID's that I intend to use for inbound calling to the system. A few things to note right off the bat:
  • Voip.ms SIP accounts are registering fine
  • I can place outbound calls and everything behaves as expected (ie, translation pattern generates outbound CID etc)
  • I have used multiple online docs for CME to Voip.ms config samples and I can't seem to get inbound calls to work.
  • As far as call flow is concerned the goal is to have the call come to an inbound dial peer (dial-peer voice 10 voip) and then be translated to the number of one of my ephone DN's (see translation-rule 8)
  • When calling either of my DID's the result is a fast-busy.
Please see the relevant parts of my config for details:
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  registrar server expires max 250 min 200
  no call service stop
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice register global
max-dn 100
max-pool 100
voice translation-rule 1
rule 1 /\(..........\)/ /9\1/
voice translation-rule 4
rule 1 /91+/ /1/
voice translation-rule 5
rule 1 /9011+/ /011/
voice translation-rule 7
rule 1 /41../ /12222222222/
rule 2 /43../ /12222222222/
rule 3 /44../ /12222244444/
rule 4 /42../ /12222255555/
voice translation-rule 8
rule 1 /2222225555/ /1000/
rule 2 /2222224444/ /1001/
voice translation-profile CALLER-ID
translate calling 7
voice translation-profile INCOMING
translate called 8
voice translation-profile INTERNATIONAL
translate calling 7
translate called 5
voice translation-profile OUT11DIGIT
translate calling 7
translate called 4
description [BDG] VOIP.MS 11 DIGIT OUT
translation-profile incoming INCOMING
translation-profile outgoing OUT11DIGIT
destination-pattern 91[2-9]..[2-9]......
session protocol sipv2
session target dns:chicago.voip.ms
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 11 voip
description [BDG] VOIP.MS INTERNATIONAL OUT
translation-profile outgoing INTERNATIONAL
destination-pattern 9011T
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
credentials username AAAAAAAA password 7 XXXXXXXXXXXX realm chicago.voip.ms
authentication username AAAAAAAA password 7 XXXXXXXXXXXXX
nat symmetric role active
nat symmetric check-media-src
no remote-party-id
retry invite 3
retry register 3
timers register 150
registrar 1 dns:chicago.voip.ms expires 300
sip-server dns:chicago.voip.ms
connection-reuse
I ran a debug voip dialpeer and here is the result during an inbound call. What I don't understand is why CME is attemping to match an inbound call to an outgoing dial peer. See below:
Aug 13 17:38:11.592: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=7736735515, Called Number=7736735515, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=7736735515
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Aug 13 17:38:11.592: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=7736735515, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
Aug 13 17:38:11.592: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Oddly enough, if I add two dial-peers like below (since it seems its looking for an outbound dial peer) the configuration works, but this is messy and a workaround.
dial-peer voice 20 voip
destination-pattern 2222225555
session target ipv4:10.1.20.2
dtmf-relay rtp-nte
no vad
dial-peer voice 21 voip
destination-pattern 2222224444
dtmf-relay rtp-nte
no vad
Does anyone have any ideas as to why this is happening?
Thanks!
  • IP Telephony
Everyone's tags (5)
Hall of Fame Super Gold
Because the translation-rule is, somehow wrong. I cannot say why is wrong without seeing the full, unedited configuration,
Hmm, that would make sense... would you mind if I PM you the full unedited config? I've seen your posts on here before and you're very frequently spot-on
Please understand that private support is for my customers only. You can probably understand what is wrong with some observation.
Ok, I understand.
What I don't understand is in the debug output it's showing that the called number is indeed exactly what the translation pattern expects (I realize it looks off in the config I posted above since I obscured the numbers in the translation output but not in the debug output) and it still doesn't route the call the the extension, the result is still a fast-busy.
Not sure, you can take some more debugs or as corner case can be a bug.
Yeah, very strange -- I just ran a debug ccsip messages because I wasn't sure whether the DNIS digits sent by Voip.ms matched my rules and if you look at the invite message (below) you'll see that it is hitting the same number as my translation pattern expects.
Aug 13 19:14:06.436: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:7736735515@OBSCUREDIP:1031 SIP/2.0
Via: SIP/2.0/UDP 64.120.22.242:5060;branch=z9hG4bK0843b058;rport
To: <7736735515>
Contact: <2245587339>
Call-ID: 4210a49116601a957d03f1803a0ada6f@64.120.22.242
CSeq: 102 INVITE
User-Agent: VoIPMS/SERAST
Max-Forwards: 70
Remote-Party-ID: "2245587339" <2245587339>;privacy=off;screen=no
Date: Mon, 13 Aug 2012 19:14:06 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces
Content-Type: application/sdp
Content-Length: 318
Please configure
dial-peer voice 10
no translation-profile incoming INCOMING
no incoming called-number
dial-peer voice 1 voip
dtmf-relay rtp-nte
codec g711ulaw
no vad
Ok,
So I have reconfigured my dial-peers as you show above and have tried placing an inbound call while running another debug voip dialpeer -- same result as before:
Aug 13 19:28:07.018: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 13 19:28:07.018: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 13 19:28:07.018: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
But the called number is 7736735515 correct?
why the translation is  rule 1 /2222225555/ /1000/ ?
If the PSTN Caller call this number 7736735515 will not match this translation
Can you try this on your translation
rule 1 /7736735515/ /1000/
Leonardo Santana
2567
