CME 8.6 Incoming PRI, Lines get dropped on second call in
I have a CCME 8.6 implmeentaiton
We brought up our PRI last night. In bound and outbound calls are working great.
Except..  Our main number is coming into our receptionist phone, if she is on with a call and anotherone comes in she puts the first on hold and wen she picks up the second the first gets dissconected.
I know i need ot make some sort of hunt group but i am not sure the exact process.
Do i setup DN's and tell them to forward on busy
IE 1001 to 1002, to 1003, etc...
I am new to cme 8.6 to be honest with you i have not touched cal manager since version 3.1 and alot has changed.
The ephone is SCCP and ephone-DN for the incoming line is an OCTO dn number 300 which is a button on the 7970.
I have ben searching for a config example but wha ti call this in the Avaya world is not he same as it is called int eh Cisco world.
Any help would be appriciated.
Everyone's tags (4)
Hello  Brandon
Can you post the config
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Here is the portions i think you would want to see ephone Dn 120 is the main line coming in and it is button number two on ephone 3
ice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip handle-replaces
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g728
codec preference 4 g729br8
codec preference 5 g723ar53
controller T1 0/1/0
cablelength short 110
pri-group timeslots 1-24
description Frontier PRI Line
no ip ftp passive
description ZDI-Network$ETH-LAN$
ip address 192.168.2.4 255.255.255.0
duplex auto
speed auto
media-type rj45
interface Service-Engine0/0
ip unnumbered GigabitEthernet0/0
service-module ip address 192.168.2.3 255.255.255.0
service-module ip default-gateway 192.168.2.4
interface GigabitEthernet0/1
description **Test Port**$ETH-LAN$
ip address 192.168.50.1 255.255.255.0
duplex auto
speed auto
media-type rj45
interface Serial0/0/0
shutdown
interface Serial0/1/0:23
no ip address
encapsulation ppp
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bchan-number-order ascending
isdn sending-complete
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 192.168.2.3 255.255.255.255 Service-Engine0/0
dial-peer cor custom
name internal
name 911
name local-call
name ld-call
name int-call
name tollfree-call
name 411
dial-peer cor list callINTERNAL
member internal
dial-peer cor list callEMERGENCY
member 911
dial-peer cor list callLOCAL
member local-call
dial-peer cor list callLD
member ld-call
member int-call
dial-peer cor list callTOLLFREE
member tollfree-call
dial-peer cor list callSERVICES
member 411
dial-peer cor list Restricted
member internal
member 911
dial-peer cor list Unrestricted
member internal
member 911
member local-call
member ld-call
member int-call
member 411
dial-peer voice 500 voip
destination-pattern 500
session protocol sipv2
session target ipv4:192.168.2.3
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 501 voip
destination-pattern 501
codec g711ulaw
no vad
dial-peer voice 502 voip
destination-pattern 502
codec g711ulaw
no vad
dial-peer voice 100 pots
corlist outgoing callEMERGENCY
description ** Outgoing EMERGENCY call to PRI trunk **
translation-profile outgoing New-PSTN-outgoing
huntstop
destination-pattern 9911
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/1/0:23
dial-peer voice 103 pots
corlist outgoing callINT
description ** Outgoing INTERNATIONAL call to PRI trunk **
translation-profile outgoing New-PSTN-Outgoing
huntstop
destination-pattern 9011T
port 0/1/0:23
dial-peer voice 104 pots
corlist outgoing callSERVICES
description ** Outgoing SERVICES call to PRI trunk **
translation-profile outgoing New-PSTN_Outgoing
huntstop
destination-pattern 9411
port 0/1/0:23
dial-peer voice 105 pots
corlist outgoing callTOLLFREE
description ** Outgoing TOLLFREE call to PRI trunk **
huntstop
destination-pattern 91800.......
port 0/1/0:23
--More--                           dial-peer voice 102 pots
corlist outgoing callLD
description ** Outgoing LD call to PRI trunk **
huntstop
destination-pattern 91[2-9]..[2-9]......
port 0/1/0:23
sip-ua
timers connect 100
telephony-service
no auto-reg-ephone
pin 12345
max-ephones 72
max-dn 500
ip source-address 192.168.2.4 port 2000
max-redirect 5
timeouts interdigit 5
timeouts ringing 30
system message Zdi, Inc.
url services
http://10.1.1.2/voiceview/common/login.do
url authentication
http://10.1.1.2/voiceview/authentication/authenticate.do
cnf-file location flash:
load 7914 S00105000400.sbn
load 7906 SCCP11.9-3-1SR3-1S.loads
load 7911 SCCP11.9-3-1SR3-1S.loads
load 7960-7940 P00308010200.loads
load 7941 SCCP41.8-3-3S.loads
load 7941GE SCCP41.8-3-3S.loads
load 7961 SCCP41.8-3-3S.loads
load 7961GE SCCP41.8-3-3S.loads
load 7970 SCCP70.8-5-4S.loads
load 7971 SCCP70.8-3-3S.loads
time-zone 8
voicemail 500
max-conferences 5 gain -6
moh flash:/music-on-hold.au
web admin system name brebbe secret 5 $1$wCUg$i4lNiiXIA4qgFNinkZ3re1
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
night-service code *1234
night-service day Sun 19:00 08:00
night-service day Mon 16:30 08:00
night-service day Tue 16:30 08:00
night-service day Wed 16:30 08:00
night-service day Thu 16:30 08:00
night-service day Fri 16:30 07:00
night-service day Sat 07:01 07:00
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  120  octo-line
number 300 secondary 309xxxxxxx no-reg both
label 309xxxxxxx
call-forward busy 501
call-forward night-service 501
call-forward noan 501 timeout 20
huntstop channel 4
no huntstop
night-service bell
ephone-dn  121
number 301 no-reg primary
label GenDelivery
call-forward busy 500
ephone  3
device-security-mode none
mac-address 0021.5555.D33A
ephone-template 1
username "jwalls"
speed-dial 1 913092082730 label "Aaron"
paging-dn 19
type 7961 addon 1 7914
button  1:3 2:120 8m18 9m4
button  10m11 11m6 12m7 13m13
button  14m8 15m15 17m14
ice service voip
sip
  registrar server
voice class codec 1
controller T1 0/1/0
no ip ftp passive
duplex auto
speed auto
media-type rj45
duplex auto
speed auto
media-type rj45
shutdown
no ip address
encapsulation ppp
ip http server
name internal
name 911
name local-call
name ld-call
name int-call
name tollfree-call
name 411
member internal
member 911
member local-call
member ld-call
member int-call
member 411
member internal
member 911
member internal
member 911
member local-call
member ld-call
member int-call
member 411
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
huntstop
port 0/1/0:23
huntstop
port 0/1/0:23
huntstop
port 0/1/0:23
huntstop
port 0/1/0:23
huntstop
port 0/1/0:23
sip-ua
timers connect 100
telephony-service
no auto-reg-ephone
pin 12345
max-ephones 72
max-dn 500
max-redirect 5
timeouts ringing 30
url services http://10.1.1.2/voiceview/common/login.do
url authentication http://10.1.1.2/voiceview/authentication/authenticate.do
time-zone 8
voicemail 500
transfer-pattern .T
label 309xxxxxxx
huntstop channel 4
no huntstop
night-service bell
ephone-dn  121
label GenDelivery
ephone  3
ephone-template 1
  paging-dn 19
Re: CME 8.6 Incoming PRI, Lines get dropped on second call in
Do u have Music on hold configured when a call goes on hold?
Just a shot in the dark may be a h245 issue iow codec miss match
Voice CCIE #37771
341
