Community Member
CME 8.6 license
Hi at all,
I've the following question/problem.
I've a CME regulary licensed.
To add new functionality I've upgraded the Router IOS and automatically was been upgraded also the cme version (from 8.5 to 8.6)
Now, with the command "show license" I've displayed the following:
Index 11 Feature: cme-srst
Period left: 6 days 17 hours
Period Used: 7 weeks 4 days
License Type: EvalRightToUse
License State: Active, In Use
License Count: 465/0 (In-use/Violation)
License Priority: Low
It's is correct?
The license will be automatically in permanet state at the end of evaluation ?
Thanks in advance
Giancarlo
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CME 8.6 license
Hi Giancarlo,
Here we go my friend, you should be "good to go".  This has been confirmed
in our recent use and is also detailed in the doc below
Activating CME-SRST Feature License
The ISR-G2 comes with a 60-day evaluation license. After 60 days, the license changes to “right to use”.
The customer is required to pay for the CME-SRST feature license which is valid for 12 years.
Prerequisites
• UCK9 license
• ISR-G2 already accepts UC CLIs
SUMMARY STEPS
1. show license detail cme-srst
2. configure terminal
3. license accept end user agreement
4. exit
5. show license detail cme-srst
6. write mem
DETAILED STEPS
Command or Action Purpose
Step 1 show license detail cme-srst
Example:
Router# show license detail cme-srst
Displays the available cme-srst license. EULA should be in NOT
ACCEPTED state.
Step 2 configure terminal
Example:
Router# configure terminal
Enters global configuration mode.
Step 3 license accept end user agreement
Example:
Router(config)# license accept end user
agreement
Configures a one-time acceptance of the EULA for cme-srst
license.
Accepts EULA by typing YES.
Step 4 exit
Example:
Router(config)# exit
Exits global configuration mode.
Step 5 show license detail cme-srst
Example:
ACCEPTED state.
Step 6 write mem
Example:
Router# write mem
Saves configuration.
Command or Action
This is explained in more detail starting on Page 15;
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.pdf
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
1 REPLY
Re: CME 8.6 license
Hi Giancarlo,
Prerequisites
• UCK9 license
SUMMARY STEPS
4. exit
6. write mem
DETAILED STEPS
Example:
ACCEPTED state.
Example:
Example:
agreement
license.
Step 4 exit
Example:
Example:
ACCEPTED state.
Step 6 write mem
Example:
Router# write mem
Command or Action
Cheers!
Rob
675
