CME 8.6 One Way Audio over PRI
Greetings,
I am having an audio issue after a power outage over the winter break.  I now have no incoming audio via CME 8.6 over our TW PRI.  We are using a 3945 running 15.1(4)M4 with a VWIC3-2MFT-T1/E1 and a PVDM3-128. ISDN seems fine and calls connect both ways but only outgoing audio works. No firewall in place, translation patterns seem fine, only one interface active, voip bind srcaddr is correct, only using G711U, all voip calls from CME to CUCM work fine. Its only calls routed out the PRI that have the problem. Telco has ran diags (remotely) and does not see a problem.
Possible DSP issue? What else can I check on my end?
Global ISDN Switchtype = primary-ni
ISDN Serial0/0/0:23 interface
        dsl 0, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        1 Active Layer 3 Call(s)
        CCB:callid=800B, sapi=0, ces=0, B-chan=23, calltype=VOICE
    Active dsl 0 CCBs = 1
    The Free Channel Mask:  0x803FFFFF
    Number of L2 Discards = 0, L2 Session ID = 1
    Total Allocated ISDN CCBs = 1
Jan  3 12:50:06.439: ISDN Se0/0/0:23 EVENT: process_pri_call: call id 0x800F, nu        mber 5127734599, Guid B11884E78124, speed 0, call type VOICE, redial No, CSM cal        l No, pdata Yes
Jan  3 12:50:06.439: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is        0x2 0x1, Calling num 5122626544
Jan  3 12:50:06.439: ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x008E callI        D = 0x800F switch = primary-ni interface = User
Jan  3 12:50:06.439: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x008E
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x2180, '512XXXXXXX'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '512XXXXXXX'
Jan  3 12:50:06.499: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8        08E
Jan  3 12:50:06.499: ISDN Se0/0/0:23 EVENT: process_rxstate: ces/callid 1/0x800F        calltype 2 CALL_PROCEEDING
Jan  3 12:50:07.479: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8  callref = 0x80        8E
        Progress Ind i = 0x8188 - In-band info or appropriate now available
Jan  3 12:50:07.479: ISDN Se0/0/0:23 EVENT: process_rxstate: ces/callid 1/0x800F        calltype 2 CALL_PROGRESS
Jan  3 12:50:16.911: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x808        E
Jan  3 12:50:16.911: ISDN Se0/0/0:23 EVENT: process_rxstate: ces/callid 1/0x800F        calltype 2 CALL_CONNECT
Jan  3 12:50:16: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 5        127734599 N/A
Jan  3 12:50:16.911: ISDN Se0/0/0:23 EVENT: isdn_neighbor_update: NLCB->State 10
Jan  3 12:50:16.911: ISDN Se0/0/0:23 EVENT: process_rxstate: ces/callid 1/0x800F        calltype 2 CALL_PROGRESS
Jan  3 12:50:16.911: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0        x008E
Hays3945#
1 REPLY
debug voip dialpeer in out. Show your dial peers better if you paste your voice settings on router
378
