CME 8.6 Outbound Caller ID
hi all,
i am relatively new to CME and recently installed a small deployment for a client everything is working as expected but i am just having issues trying to set the outbound callier ID to the users DDI as opposed to the main number.
the company has a DDI range and users would like there direct dials to display on outbound calls and not the main number as it is currently
inbound calls to users DDIs are working fine
please see below config snipet
* note XXXXXX i removed the full numbers for security but each 4 didgit ext matches their DDI
voice translation-rule 7
rule 1 /^3920/ /0207XXXXXXX/
rule 2 /^3921/ /0207XXXXXXX/
rule 3 /^3922/ /0207XXXXXXX/
rule 4 /^3923/ /0207XXXXXXX/
rule 5 /^3924/ /0207XXXXXXX/
rule 6 /^3925/ /0207XXXXXXX/
rule 7 /^3926/ /0207XXXXXXX/
rule 8 /^3927/ /0207XXXXXXX/
rule 9 /^3928/ /0207XXXXXXX/
rule 10 /^3929/ /0207XXXXXXX/
voice translation-profile InboundDID
translate called 7
voice translation-profile OUTBOUND_CLI_DISPLAY
translate calling 7
translate called 7
dial-peer voice 1 pots
description ISDN30 OUTBOUND
translation-profile outgoing OUTBOUND_CLI_DISPLAY
destination-pattern 0T
port 0/0/0:15
forward-digits all
ephone-dn  5  dual-line
number 3922 secondary 0207XXXXXXX no-reg primary
if i debug the dial-peer i can see it matching dial-peer 1 but still displaying the incorrect number
from what i have read i believe i have configured this correctly but any pointers would be greatly recieved
Jul  3 15:02:24.007: //-1/E85E49668CA5/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=1
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CME 8.6 Outbound Caller ID
Chec debug isdn q931 to see what is actually being sent out.
Note you can also use pattern recall in translation-rule to avoid listing each DID.
hi paolo,
thanks for the pointer;
on running the debug and making a test call i can see that the calling number being sent is the users DDI therefore i believe the ISDN provider might not be passing the presented number; might be a case of them having to enable CLOP.
i have removed the full number from the debug but can see it sending the number correctly
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
Jul  4 07:27:22.833: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 0207XXXXXXX
Jul  4 07:27:22.837: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0093 callID = 0x8014 switch = primary-net5 interface = User
Jul  4 07:27:22.837: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0093
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98388
Exclusive, Channel 8
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '0207XXXXXXX'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '0777XXXXXXX'
Jul  4 07:27:22.973: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8093
VIP Super Bronze
If the calling number is within the allocated DDI, then go and have a word with the Telco provider. From the number it looks like you are in the UK. I think some of the providers charge for you to have CLID displayed. So speak to them
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
that is correct i am in the UK.
i am having the telco check there CLID settings for the circuit will report back shortly.
Gold
Hi Barnaby
The other thing that I've found in the UK is that some carriers (Virgin Media in particular) require you to set the calling plan to "ISDN" and the type to "national", otherwise they don't honour the CLID settings.
rule 1 /^3920/ /0207XXXXXXX/ type any national plan any ISDN
Hope this helps. Barry
Barry Hesk
Intrinsic Network Solutions
2698
