CME 8.6 - SIP - H323 no voice
Anatoly Fedchik
could you help me, when i call from SIP phone 9951 to AVAYA over H323 there is no voice, but call is established.
Thanks in advance
voice register global
mode cme
source-address 192.168.4.192 port 5060
max-dn 5
max-pool 5
load 9951 sip9951.9-2-3-27
authenticate register
authenticate realm all
timezone 32
time-format 24
date-format D/M/Y
tftp-path flash:
file text
create profile sync 000410054377842A
voice register dn  1
number 85709
allow watch
name user1
no-reg
label user1
mwi
voice register pool  1
id mac 64D9.89C3.C654
type 9951
number 1 dn 1
dtmf-relay sip-notify
username cisco password cisco
codec g711ulaw
no vad
dial-peer voice 201 voip
destination-pattern .T
session target ipv4:192.168.25.10
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
6 Replies 6
paolo bevilacqua
do you have a firewall between systems ?
Run the following debugs and then paste them here and I'll check them out:
debug voip ccapi inout
debug ccsip messages
debug h225 asn1
debug h245 asn1
If possible upload a txt file since the output may be very extensive.
vickskwt1
in the interface config, have you added the following line:
h323-gateway voip bind srcaddr a.b.c.d
NOTE: replace a.b.c.d with the ip addr of your interface
Also please attach the sh run se we can have a look this seems to be a codec problem, if no firewall is in the middle.
Robert Thomas
Level 7
Level 7
Debug voip rtp packets to see the RTP packet exchange.
Debug h245 asn1 to see the IP Address and port number exchanged between the CME and the avaya.
Anatoly Fedchik
Thank you for your answers, the problem is solved.
Helped the following config:
Voice service VoIP
H323
Call start interwork
