CME 8.6 Voicemail Transfer issue
hi all,
wondering if someone can help point me in the right direction regarding a voicemail transfer issue i am experiencing.
customer has a small CME deployment 1 receptionst and around 5 other individual users.
the Receptionst (ephone 7) has her own line but also on the spare line buttons she has other users lines in the event the users are out of the office so she can pickup there calls.
the problem i am having is that when she answers one of these other lines and then wishes to transfer them to that indiviuals voicemail she cant as she is in effect already on that line
im thinking there must be a better way to configure this on the Receptionst phone to enable her to still answer the users direct dials but enable her to transfer to that users ext which will then follow there call-forward noan action
suggestions greatly appreciated
ephone-dn  3  dual-line
number 3920 secondary 0207XXXXXXX no-reg primary
pickup-group 8080
label Reception 3920
description Reception
name Reception
call-forward noan 8000 timeout 20
translation-profile outgoing OUTBOUND_CLI_DISPLAY
ephone-dn  4  dual-line
number 3921 secondary 0207XXXXXXX no-reg primary
pickup-group 8080
label XXXXXX 3921
description XXXXXX
call-forward busy 3920
call-forward noan 8000 timeout 10
ephone  7
mac-address XXXX.XXXX.XXXX
username "reception" password XXXXXX
type 7965 addon 1 7915-12
button  1:3 2:4 3:5 4:1
telephony-service
no auto-reg-ephone
max-ephones 30
max-dn 50
ip source-address 10.1.4.254 port 2000
max-redirect 5
service phone ehookEnable 1
timeouts interdigit 3
system message XXXXXXXX
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.2/CCMCIP/authenticate.asp
cnf-file location flash:
load 7915-12 B015-1-0-4.SBN
load 7915-24 B015-1-0-4.SBN
load 7906 SCCP11.9-1-1SR1S.loads
load 7911 SCCP11.9-1-1SR1S.loads
load 7937 apps37sccp.1-4-4-0.bin
load 7960-7940 P00308010200.loads
load 7945 SCCP45.9-1-1SR1S.loads
load 7965 SCCP45.9-1-1SR1S.loads
load 7970 SCCP70.9-1-1SR1S.loads
load 7971 SCCP70.9-1-1SR1S.loads
time-zone 21
time-format 24
voicemail 8000
max-conferences 8 gain -6
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp 7960 Jul 03 2012 16:17:49
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Have her transfer to VM number.
If that doesn't work, there is another config to transfer any call directly to any VM box.
paolo,
thanks again for the pointer
i configured the cme to directly transfer the call to unity express voicemail
firstly i created a DN in CME which points to the voicemail pilot number 8000
ephone-dn  22
number 7....
description ***dial 7 then ext number 4vmail
call-forward all 8000
i then connected to the CUE and configured each user with a phonenumberE164 with the users extension prefixed with a 7
username XXXX phonenumberE164 "73923"
username XXXX phonenumberE164 "73920"
username XXXX phonenumberE164 "73922"
username XXXX phonenumberE164 "73921"
when a call now comes in on one of the DDI's and the receptionist answers the call and wishes to transfer to that users voicemail she presses transfer then 7 followed by the users extension number
As an alternative to configuring an additional phonenumberE164 for each user, you can add a voice translation-profile under
CUE DP, that strips leadning 7 from redirecting number.
You can also use a softkey for transferVM.
Thanks for the nice rating and good luck!
Hall of Fame Super Red
Hi Barnaby,
Just to add a note to the great tips from my friend Paolo (+5 "P")
The steps required are nicely detailed in this good Tech Note;
Transfer a Caller Directly into a Unity Express Mailbox
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a00802ab979.shtml#cue_int_ccm_exp
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
ROB
Thanks for sharing the link ! Extremely helpful !  + 5
Lavanya
I needed the "call-forward pattern .T" statement in my telephony-service part of the config for my call forward no answer to work as well as the statement "transfer-pattern 200." (where 200 was the beginning of my extension nmbers (2001, 2002, 2003,,etc). Don't know if you need this as well..Just a thought.
1961
