CME 8.6 with VG224 hotdial
I am trying to get a plain analog phone to be a "hotdial" type of phone. It is connected to a VG224 and controlled by CME 8.6 on a 3945 router. I've tried the "connection plar xxxx" command on the voice-port of the vg224, but the system seems to ignore it.
Has anyone successfully done this? If so, I would greatly appreciate an example.
Thank you.
Gordon
  • IP Telephony
Green
Gordon,
Is the vg224 using sccp (skinny) to the cme
If it is you set up the plar like this:-
sccp plar
voiceport 2/0 dial 4444
dial-peer voice 1000 pots
service stcapp
port 2/0
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Thank you Alex. That looks like exactly what I'm searching for. I will give it a try.
Bronze
Re:CME 8.6 with VG224 hotdial
All Cisco vg224 voice ports are FXS ports that do not support command ( connection plar) . What you trying to do exactly?
Sent from Cisco Technical Support Android App
Thank you Saif. I am aware that they are all FXS ports, but I think Alex has come up with the answer.
This is for a phone by an outside parking lot gate that only needs to ring to the security desk.
228
