CME 8.6 with Voip.ms - Outbound works, no inbound - UPDATED
Hello again everyone,
I had originally made a post that had asked about this problem and it was immediately noticed that I was not receiving the correct (external IP) IP address assignment on my outside facing ethernet port.  I have since corrected this problem after hours on the phone with comcast.
Here is the updated running-config and the debug ccsip messages.  Instead of having a "BAD HOST" message on the ccsip debug messages I am not receiving a "404 Not Found" message when dialing in along with a fast busy signal.
The system is registering with the SIP service provider correctly. (Voip.ms)
Here is the current layout
Comcast Modem ----->----- Cisco 3825 ------>------ Switch ------>------ IP Phone
I have 2 DID phone numbers purchased.  Neither dial in but both dial out and caller ID works for each number.
The 3825 has an outside IP address on the G0/0 interface and an internat IP address on the G0/1 interface
any recommendations are welcome.
I have not yet set up sub interfaces for QoS/Vlan segregation for the IP Phones as the switch is a dell powerconnect and I just haven't gotten that far with it yet.
  • IP Telephony
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: CME 8.6 with Voip.ms - Outbound works, no inbound - UPDATED
Matt,
So here are my two suggestions do one at a tim.
First I would try binding sip source traffice to my public address...
Second I would create a DN  or assign a secondary number  to a phone with a number that matches the called number.
so 1001 seconary number full number.
I am not seeing your translations happening to convert your number into your private extension.
Let me know if this helps!
Matt,
I inserted the bind commands in the voice service voip - SIP area
bind media control source-interface gigabitethernet0/0
and
bind media source-interface gigabitethernet 0/0
NO LUCK
I added the phone numbers to the ephone-dn 1 and ephone-dn 2 area as a secondary number and the calls completed.
IT WORKS !
I had at one point put the external phone nunmbers in as secondary, but had for some reason removed them in my many attemps to fix the config.
I tried removing the bind commands which broke the ability to receive calls.  They were absolutely necessary.
Thank you Mr. Brunn.  I appreciate your input and look forward to being able to assist you and others in the future should you need it.
Matt,
I had this exact problem with a sip service provider when I was with a previous company.  When you are stuck in the field with a problem you tend to remenber it.
Happy your part of the community!
No need to call me Mr.
315
