CME 8.8 incoming call from sip trunk displays "caller unknown" on all SCCP phones
Hi all,
I'm facing this weird situation:
Scenario:
Cisco CME 8.8 (c2900-universalk9-mz.SPA.152-1.T4.bin) on 2901 platform, some Cisco 7945 and Cisco 6921 ip phone with sccp firmware onboard.
All incoming and outgouing calls, are placed via a SIP trunk directly to/from the provider using the below configuration;
all in/out calls go fine, the issue I get is:
all incoming calls to all the ip phones, displays "caller unknown" despite the provider pass me the correct uri, as I can see debugging the sip call.
Seems that something else has to be enabled in config in order to correct display the incoming number, ... or I don't know
please help
thank you everybody
Emanuele
voice translation-rule 1
rule 1 /^00/ /0/
rule 2 /^03/ /3/
rule 3 /^01/ /1/
rule 4 /^02/ /2/
rule 5 /^04/ /4/
rule 6 /^05/ /5/
rule 7 /^06/ /6/
rule 8 /^07/ /7/
rule 9 /^08/ /8/
rule 10 /^09/ /9/
voice translation-profile profile1
translate called 1
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
h323
sip
  registrar server
  redirect contact order best-match
telephony-service
authentication credential ******** *******
max-ephones 42
max-dn 200
ip source-address 192.168.100.1 port 2000
calling-number initiator
service phone ehookEnable 1
service phone webAccess 0
service dnis dir-lookup
timeouts interdigit 5
system message ***************************
url services
http://10.10.10.1/voiceview/common/login.do
url authentication
http://10.10.10.1/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
user-locale IT load CME-locale-it_IT-Italian-8.8.2.3.tar
network-locale IT
load 7945 SCCP45.9-3-1SR2-1S.loads
load 6921 SCCP69xx.9-3-3-2.loads
time-zone 26
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh "music-on-old.au"
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
directory last-name-first
create cnf-files version-stamp Jan 01 2002 00:00:00
dial-peer voice 1000 voip
description TRUNK SIP
translation-profile outgoing profile1
destination-pattern T
redirect ip2ip
session protocol sipv2
session target ipv4:NNN.NNN.NNN.NNN
incoming called-number .T
voice-class codec 2
dtmf-relay rtp-nte
no vad
num-exp 02929691.. 2..
num-exp 02929691 205
268
