CME 8 install LOAD COMMAND ERROR:
I am trying to setup cme 8 on a cisco 2801 running ios 15.1.T.
I have downloaded cme-basic-8.0.0.0.tar and cme-151-Tv2 on to flash.
I am going to use 7940 in the lab so I removed most of the other phone loads before extracting the file so that I could fit it in to the flash.
I have noticed that the "show flash" command shows the path as:
flash/P00308000500.sbn
The command "dir flash" command did not list the file.
So I copied it to the from the flash directory to flash so that it would be listed under the "dir flash:" command.
I have then added the files to router for the tftp-server:
tftp-server flash:/flash/os79xx.txt
tftp-server flash:/flash/P0S3-8-12-00.loads
tftp-server flash:/flash/P0S3-8-12-00.sb2
tftp-server flash:P003-8-12-00.sbn
tftp-server flash:P00308000500.loads
tftp-server flash:P00308000500.sb2
tftp-server flash:P00308000500.sbn
tftp-server flash:P00308000500.bin
I then proceed with telephony-service
CME_LAB(config-telephony)#load 7960-7940 P00308000500.sbn
LOAD COMMAND ERROR:cnf-file location system is not supported for creating automatic tftp bindings. Please use file location flash | slot0 | tftp OR create tftp bindings manually
ME_LAB(config-telephony)#load 7960-7940 P00308000500.bin
Weirdly is I add "]" at the end of the file extension it parses except for the .bin file
Any ideas on how to proceed?
If I try to create the cnf files it errors with
CME_LAB(config-telephony)#create cnf-files
Post-init cnf creation is in progress, pls re-issue this command later
Also do I need a device license for cme 8.x as I am using it for lab purposes only?
Currently it says
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2801             FCZ0947117X
Feisal
Re: CME 8 install LOAD COMMAND ERROR:
I have added the cnf location flash: command and that has got rid of the error.
LOAD COMMAND ERROR:cnf-file location system is not supported for creating automatic tftp bindings. Please use file location flash | slot0 | tftp OR create tftp bindings manually.
I get this error when creating the cnf-files, am I missing something. I haven't configured ntp yet but I don't think that should matter.
"Post-init cnf creation is in progress, pls re-issue this command later"
Feisal
6283
