CME 8 ringlist.xml
Hi everyone,
I can't seem to figure this out - when the phones boot up they display file not found: distinct  and file not found ringlist.xml. I checked the tftp server settings as shown below in the config and the ringtone files & Ringlist.xml and DistinctiveRingList.xml are present on the flash card. I also rebooted the router. The only 2 ringtones showing up are chirp.
David
------------------ show version ------------------
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 15.1(1)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 22-Mar-10 01:25 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
CME uptime is 9 minutes
System image file is "flash:c2800nm-ipvoicek9-mz.151-1.T.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2851 (revision 53.51) with 512000K/12288K bytes of memory.
Processor board ID FTX1212A1DS
2 Gigabit Ethernet interfaces
1 terminal line
4 Voice FXO interfaces
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#       PID               SN
*0         CISCO2851             FTX1212A1DS
------------------ show running-config ------------------
Building configuration...
Current configuration : 6955 bytes
! Last configuration change at 17:11:54 UTC Thu May 10 2012
version 15.1
hostname CME
boot-start-marker
boot-end-marker
enable secret 5 <removed>
enable password <removed>
no aaa new-model
no network-clock-participate slot 1
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.1.1 172.16.1.10
ip dhcp pool VOICE
   network 172.16.1.0 255.255.255.0
   default-router 172.16.1.1
   option 150 ip 172.16.1.1
ip name-server 4.2.2.2
no ipv6 cef
voice rtp send-recv
voice service voip
 gcid
 clid substitute name
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 sip
  e911
  transport switch udp tcp
  asserted-id ppi
  midcall-signaling passthru
  no call service stop
voice class codec 1
 codec preference 1 g729r8
 codec preference 2 g711ulaw
 codec preference 3 g711alaw
voice class h323 1
  telephony-service ccm-compatible
  ccm-compatible
voice translation-rule 2
 rule 1 /105/ /5164038926/
voice translation-rule 3
 rule 1 /5164038959/ /105/
voice translation-profile INCOMING
voice-card 0
voice-card 1
license udi pid CISCO2851 sn FTX1212A1DS
archive
 log config
  hidekeys
username cisco privilege 15 password 0 <removed>
username user3 password 0 <removed>
interface GigabitEthernet0/0
 description LAN_INTERFACE
 ip address 172.16.1.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly
 duplex auto
 speed auto
 no mop enabled
interface Service-Engine0/1
 ip address 172.16.200.1 255.255.255.252
 service-module ip address 172.16.200.2 255.255.255.252
 service-module ip default-gateway 172.16.200.1
interface GigabitEthernet0/1
 description WAN_INTERFACE
 ip address xx.xxx.xx.xxx 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
 no mop enabled
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 xx.xxx.xx.1
access-list 1 permit 172.16.1.0 0.0.0.255
dialer-list 1 protocol ip permit
tftp-server flash:term06.default.loads
tftp-server flash:term41.default.loads
tftp-server flash:P00308010200.bin alias P00308010200.bin
tftp-server flash:P00308010200.loads alias P00308010200.loads
tftp-server flash:P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:P00308010200.sbn alias P00308010200.sbn
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:/Ringtones/Ringlist.xml
tftp-server flash:/Ringtones/DistinctiveRingList.xml
tftp-server flash:/Ringtones/AreYouThereF.raw
control-plane
voice-port 1/0/0
 connection plar opx 102
 caller-id enable
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
dial-peer voice 100 voip
 description DIAL_PEER_TO_CUE
 destination-pattern 77[5-9]
 session protocol sipv2
 session target ipv4:172.16.200.2
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 10 pots
 description POTS_DIAL_PEER_OUTGOING
 destination-pattern 1[2-9]..[2-9]......
 port 1/0/0
dial-peer voice 1 voip
 incoming called-number 51640389..
 voice-class sip asserted-id ppi
 no voice-class sip block 180
 no voice-class sip block 183
 no voice-class sip block 181
 voice-class sip pass-thru headers unsupp
 voice-class sip pass-thru content unsupp
 voice-class sip pass-thru content sdp
 dtmf-relay rtp-nte
dial-peer voice 2 voip
 destination-pattern [2-9]..[2-9]......
 session target ipv4:74.63.41.218
 session transport udp
 dtmf-relay rtp-nte
 codec g711ulaw
telephony-service
 authentication credential cisco cisco
 max-ephones 30
 max-dn 45
 ip source-address 172.16.1.1 port 2000
 system message IPO Law Group
 url services http://172.16.200.2/voiceview/common/login.do
 url authentication http://172.16.200.1/CCMCIP/authenticate.asp
 cnf-file location flash:
 load 7960-7940 P00308010200
 load 7941 term41.default.loads
 load 7942 term42.default.loads
 load 7945 term70.default.loads
 load 7961 term06.default.loads
 load 7962 term62.default.loads
 load 7965 term71.default.loads
 max-conferences 4 gain -6
 moh flash:music-on-hold.au
 multicast moh 239.1.1.1 port 2000
 web admin system name cisco password <removed>
 dn-webedit
 time-webedit
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
 number 101
 call-forward noan 777 timeout 16
ephone-dn  2  dual-line
 number 102
ephone-dn  3  dual-line
 number 103
 call-forward busy 777
ephone-dn  4  dual-line
 number 104
ephone-dn  5  dual-line
 number 5164038959
 description DID 1 VOIPMS
ephone-dn  6  dual-line
 number 106
ephone-dn  7  dual-line
 number 107
ephone-dn  8  dual-line
 number 108
ephone-dn  9  dual-line
 number 109
ephone-dn  10  dual-line
 number 110
ephone-dn  11  dual-line
 number 111
ephone-dn  12  dual-line
 number 112
ephone-dn  13  dual-line
 number 113
ephone-dn  14  dual-line
 number 114
ephone-dn  15  dual-line
 number 115
ephone-dn  16  dual-line
 number 116
ephone-dn  17  dual-line
 number 117
ephone-dn  18  dual-line
 number 118
ephone-dn  19  dual-line
 number 119
ephone-dn  20  dual-line
 number 120
ephone-dn  21  dual-line
 number 121
ephone-dn  22  dual-line
 number 122
ephone-dn  23  dual-line
 number 123
ephone-dn  24  dual-line
 number 124
ephone-dn  25  dual-line
 number 125
ephone-dn  26  dual-line
 number 126
ephone-dn  27  dual-line
 number 127
ephone-dn  28  dual-line
 number 128
ephone-dn  29  dual-line
 number 129
ephone-dn  30  dual-line
 number 130
ephone  2
 mac-address 0013.60B5.26F1
 username "user2"
 type 7960
 button  1:2
ephone  3
 mac-address 000E.D759.515C
 type 7940
 button  1:3 2:5
line con 0
line aux 0
line 258
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
 password <removed>
 login
 transport input all
scheduler allocate 20000 1000
end
Everyone's tags (4)
1 ACCEPTED SOLUTION
CME 8 ringlist.xml
change Ringlist.xml to RingList.xml
aslo do
tftp-server flash:/Ringtones/RingList.xml alias RingList.xml
tftp-server flash:/Ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
CME 8 ringlist.xml
aslo do
CME 8 ringlist.xml
No luck... File Not Found: RINGLIST.XML
Hall of Fame Super Gold
CME 8 ringlist.xml
Etiehr the file is missing, or tftp statements are not configured correctly.
Blue
CME 8 ringlist.xml
Please enter following the rings.raw file in tftp-server command  also
e.g. tftp-server flash:RingList.xml
       tftp-server flash:Piano1.raw
       tftp-server flash:Chime.raw
Ronak Patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Re: CME 8 ringlist.xml
Ok, working now Thanks for the help. When I pulled the config again the tftp servers were a mess, so I redid all the ringtone and ringlist server flies and aliased the DistinctiveRingList.xml, RingList.xml and all the voice files like Tun Moe said and it came up.
Thanks!
3018
