09-04-2013 12:43 PM - edited 03-16-2019 07:12 PM
How would you or can you enable web access enable a phone on a Call Manager Express? So on CUCM I would select the phone and on the device settings pick Web Access Enabled. This allows me to ip to the phone and retrieve things such as QOS. But Not sure how this works for the Call Manager express. Does anyone have any idea's?
Solved! Go to Solution.
09-04-2013 12:53 PM
This has been covered already in this post:
https://supportforums.cisco.com/thread/2010393
Basically enter the following:
Telephony-service
Service phone webAccess 1
Create cnf-files
Note: you need to reset the phones for this to take effect.
Kind Regards,
Stephen Welsh
Enroll for Unified FX’s FREE Educational seminars on The Essentials of Endpoint Security & Compliance
• Session 1: The Impact of Security by Default (5th Sept)
• Session 2: Understanding and Managing ITL & CTL Files (12th Sept)
• Session 3: Leading Practices for Endpoint Security & Compliance (19th Sept)
Spaces are limited and we anticipate high demand, so please register early:
09-04-2013 12:53 PM
Telephony-service
Create cnf-files
Kind Regards,
Stephen Welsh
