cme 9.0 call transfer failed from 8961 sip phone : Cannot Complete Transfer
Using a 2921, IOS 152-2.T (cme 9.0) from a 8961 sip phone, call transfer to any type of phone from failed : "Cannot Complete Transfer"
call transfer with a sccp phone works fine.
Any thought ?
DV
Feb 14 09:14:42.023: //-1/49ACC544AF19/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=2948
   ----- ccCallInfo IE subfields -----
   cisco-ani=sip:2948@10.41.8.250
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=sip:6890@10.86.8.250:5060
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Feb 14 09:14:42.023: //-1/49ACC544AF19/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x30AF2250, Call Info(
   Calling Number=sip:2948@10.41.8.250,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=sip:6890@10.86.8.250:5060(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=6899, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=3732
Feb 14 09:14:42.023: //-1/49ACC544AF19/CCAPI/ccCheckClipClir:
   In: Calling Number=sip:2948@10.41.8.250(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=sip:2948@10.41.8.250(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Feb 14 09:14:42.023: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 09:14:42.023: :cc_get_feature_vsa malloc success
Feb 14 09:14:42.023:  cc_get_feature_vsa count is 1
Feb 14 09:14:42.023: :FEATURE_VSA attributes are: feature_name:0,feature_time:1073772472,feature_id:680
Feb 14 09:14:42.023: //3732/49ACC544AF19/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Feb 14 09:14:42.023: //3732/49ACC544AF19/CCAPI/cc_process_call_setup_ind:
   Event=0x30A40A40
Feb 14 09:14:42.023: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 6890
Feb 14 09:14:42.027: //3732/49ACC544AF19/CCAPI/ccCallSetContext:
   Context=0x417A8D74
Feb 14 09:14:42.027: //3732/49ACC544AF19/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 3732 with tag 6899 to app "_ManagedAppProcess_Default"
Feb 14 09:14:42.027: //3732/49ACC544AF19/CCAPI/ccCallProceeding:
Feb 14 09:14:42.027: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
   mempool not found from usrContainer(2CD0224C)
Feb 14 09:14:42.027: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
   Mempool(2B7903A8) created in usrContainer(2CD0224C)
Feb 14 09:14:42.027: //3732/49ACC544AF19/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=40001, Params=0x417ACAE4, Progress Indication=NULL(0)
Feb 14 09:14:42.027: //3732/49ACC544AF19/CCAPI/ccCheckClipClir:
   Destination Pattern=6890$, Called Number=6890, Digit Strip=FALSE
   Calling Number=sip:2948@10.41.8.250(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=6890(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Damien Vigny
   Account Number=2948, Final Destination Flag=TRUE,
   Guid=49ACC544-5623-11E1-AF19-BDE8B88A67D4, Outgoing Dial-peer=40001
Feb 14 09:14:42.027: //3732/49ACC544AF19/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=2948
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=6890
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Feb 14 09:14:42.027: //3732/49ACC544AF19/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x30AF2250, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=sip:2948@10.41.8.250,(Calling Name=Damien Vigny)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=6890(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=40001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Feb 14 09:14:42.027: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 09:14:42.027: :cc_get_feature_vsa malloc success
Feb 14 09:14:42.027:  cc_get_feature_vsa count is 2
Feb 14 09:14:42.027: :FEATURE_VSA attributes are: feature_name:0,feature_time:1073770904,feature_id:681
Feb 14 09:14:42.027: //3733/49ACC544AF19/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Feb 14 09:14:42.027: //3733/49ACC544AF19/CCAPI/ccCallSetContext:
   Context=0x417ACA94
Feb 14 09:14:42.027: //3732/49ACC544AF19/CCAPI/ccSaveDialpeerTag:
Feb 14 09:14:42.031: //3733/49ACC544AF19/CCAPI/cc_api_event_indication:
   Event=185, Call Id=3733
   Event Is Sent To Conferenced SPI(s) Directly
Feb 14 09:14:42.031: //3732/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 14 09:14:42.031: cc_api_get_xcode_stream : 4803
Feb 14 09:14:42.031: //3733/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 14 09:14:42.031: //3733/49ACC544AF19/CCAPI/cc_api_call_proceeding:
   Interface=0x30AF2250, Progress Indication=NULL(0)
Feb 14 09:14:42.367: //3733/49ACC544AF19/CCAPI/cc_api_call_alert:
   Interface=0x30AF2250, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Feb 14 09:14:42.367: //3732/49ACC544AF19/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Feb 14 09:14:45.251: //3733/49ACC544AF19/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=3733,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Feb 14 09:14:45.251: //3732/49ACC544AF19/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=3733, Source Call Id=3732,
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
   Caps(Codec=gsmefr(0x0), Fax Rate=Invalid(0x0), Vad=Invalid(0x10),
   Modem=Invalid(0x1003C), Codec Bytes=0, Signal Type=1, Seq Num Start=2622440)
Feb 14 09:14:45.251: //3733/49ACC544AF19/CCAPI/cc_api_event_indication:
   Event=175, Call Id=3733
Feb 14 09:14:45.255: //3733/49ACC544AF19/CCAPI/cc_api_call_connected:
   Interface=0x30AF2250, Data Bitmask=0x81000001, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Feb 14 09:14:45.255: //3732/49ACC544AF19/CCAPI/ccConferenceCreate:
   (confID=0x2B774D58, callID1=0xE94, gcid=29A34B35-562311E1-93308E15-E3B21876, tag=0x0)
Feb 14 09:14:45.255: //3733/49ACC544AF19/CCAPI/ccConferenceCreate:
   (confID=0x2B774D58, callID2=0xE95, gcid=29A34B35-562311E1-93308E15-E3B21876, tag=0x0)
   Conference Id=0x2B774D58, Call Id1=3732, Call Id2=3733, Tag=0x0
Feb 14 09:14:45.255: //3732/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 14 09:14:45.255: cc_api_get_xcode_stream : 4803
Feb 14 09:14:45.255: //3733/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 14 09:14:45.255: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=6
                    ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=6,
                    tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
                    tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
   delay media to slow start case, codec negotation is not done
Feb 14 09:14:45.255: //3732/49ACC544AF19/CCAPI/cc_api_bridge_done:
   Conference Id=0xD4, Source Interface=0x30AF2250, Source Call Id=3732,
   Destination Call Id=3733, Disposition=0x0, Tag=0x0
Feb 14 09:14:45.255: //3733/49ACC544AF19/CCAPI/cc_api_bridge_done:
   Conference Id=0xD4, Source Interface=0x30AF2250, Source Call Id=3733,
   Destination Call Id=3732, Disposition=0x0, Tag=0x0
Feb 14 09:14:45.255: //3732/49ACC544AF19/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0xD4, Destination Call Id=3733)
   Call Entry(Conference Id=0xD4, Destination Call Id=3732)
Feb 14 09:14:45.255: //3732/49ACC544AF19/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xD4, Call Id1=3732, Call Id2=3733
Feb 14 09:14:45.255: //3732/49ACC544AF19/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x81000001
   Call Entry(Connected=TRUE, Responsed=TRUE)
Feb 14 09:14:45.567: //3732/49ACC544AF19/CCAPI/cc_api_event_indication:
   Event=197, Call Id=3732
Feb 14 09:14:50.371: //-1/2E9C7A979334/CCAPI/cc_api_display_ie_subfields:
   cisco-username=6890
   cisco-ani=sip:6890@10.86.8.250
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=sip:6@10.86.8.250;user=phone
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Feb 14 09:14:50.371: //-1/2E9C7A979334/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=sip:6890@10.86.8.250,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=sip:6@10.86.8.250;user=phone(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=40001, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=3734
Feb 14 09:14:50.371: //-1/2E9C7A979334/CCAPI/ccCheckClipClir:
   In: Calling Number=sip:6890@10.86.8.250(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=sip:6890@10.86.8.250(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Feb 14 09:14:50.371: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 09:14:50.371: :cc_get_feature_vsa malloc success
Feb 14 09:14:50.371:  cc_get_feature_vsa count is 3
Feb 14 09:14:50.371: :FEATURE_VSA attributes are: feature_name:0,feature_time:1073770680,feature_id:682
Feb 14 09:14:50.371: //3734/2E9C7A979334/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Feb 14 09:14:50.375: //3734/2E9C7A979334/CCAPI/cc_process_call_setup_ind:
   Event=0x30A3D6B0
Feb 14 09:14:50.375: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Feb 14 09:14:50.375: //3734/2E9C7A979334/CCAPI/ccCallSetContext:
   Context=0x417A3BF4
   >>>>CCAPI handed cid 3734 with tag 40001 to app "_ManagedAppProcess_Default"
Feb 14 09:14:50.375: //3734/2E9C7A979334/CCAPI/ccCallSetupAck:
   Call Id=3734
Feb 14 09:14:50.375: //3734/2E9C7A979334/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Feb 14 09:14:50.375: //3734/2E9C7A979334/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Feb 14 09:14:50.375: //3734/2E9C7A979334/CCAPI/ccCallReportDigits:
   (callID=0xE96, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=3734
Feb 14 09:14:50.879: //3734/2E9C7A979334/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x30AF2250, callID=0xE96, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x30AF2250, Call Id=3734
   Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
Feb 14 09:14:51.195: //3734/2E9C7A979334/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
   Source Call Id=3734, Digit=8, DigitBeginFlags=0x0,
   Rtp Timestamp=0x0, Rtp Expiration=0x0
Feb 14 09:14:51.195: //3734/2E9C7A979334/CCAPI/cc_api_call_digit_end:
   Source Call Id=3734, Digit=8, Duration=250,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Feb 14 09:14:51.499: //3734/2E9C7A979334/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3734, Digit=9, DigitBeginFlags=0x0,
Feb 14 09:14:51.499: //3734/2E9C7A979334/CCAPI/cc_api_call_digit_end:
   Source Call Id=3734, Digit=9, Duration=250,
Feb 14 09:14:51.811: //3734/2E9C7A979334/CCAPI/cc_api_call_digit_begin:
   Source Call Id=3734, Digit=2, DigitBeginFlags=0x0,
Feb 14 09:14:51.811: //3734/2E9C7A979334/CCAPI/cc_api_call_digit_end:
   Source Call Id=3734, Digit=2, Duration=250,
Feb 14 09:14:51.815: //3734/2E9C7A979334/CCAPI/ccCallReportDigits:
   (callID=0xE96, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb 14 09:14:51.815: //3734/2E9C7A979334/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x30AF2250, callID=0xE96, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb 14 09:14:51.815: //3734/2E9C7A979334/CCAPI/ccCallProceeding:
Feb 14 09:14:51.815: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
   mempool not found from usrContainer(2CD03CDC)
Feb 14 09:14:51.815: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
   Mempool(321741B4) created in usrContainer(2CD03CDC)
Feb 14 09:14:51.815: //3734/2E9C7A979334/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=40004, Params=0x417A27E4, Progress Indication=NULL(0)
Feb 14 09:14:51.815: //3734/2E9C7A979334/CCAPI/ccCheckClipClir:
   Destination Pattern=6892$, Called Number=6892, Digit Strip=FALSE
   Calling Number=sip:6890@10.86.8.250(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=6892(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=dvigny-6890
   Account Number=6890, Final Destination Flag=FALSE,
   Guid=2E9C7A97-5623-11E1-9334-8E15E3B21876, Outgoing Dial-peer=40004
Feb 14 09:14:51.815: //3734/2E9C7A979334/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=6890
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=6892
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Feb 14 09:14:51.815: //3734/2E9C7A979334/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=sip:6890@10.86.8.250,(Calling Name=dvigny-6890)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=6892(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=FALSE, Outgoing Dial-peer=40004, Call Count On=FALSE,
Feb 14 09:14:51.815: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 14 09:14:51.815: :cc_get_feature_vsa malloc success
Feb 14 09:14:51.815:  cc_get_feature_vsa count is 4
Feb 14 09:14:51.815: :FEATURE_VSA attributes are: feature_name:0,feature_time:1073771128,feature_id:683
Feb 14 09:14:51.815: //3735/2E9C7A979334/CCAPI/ccIFCallSetupRequestPrivate:
Feb 14 09:14:51.815: //3735/2E9C7A979334/CCAPI/ccCallSetContext:
   Context=0x417A2794
Feb 14 09:14:51.815: //3734/2E9C7A979334/CCAPI/ccSaveDialpeerTag:
Feb 14 09:14:51.819: //3735/2E9C7A979334/CCAPI/cc_api_event_indication:
   Event=185, Call Id=3735
Feb 14 09:14:51.819: //3734/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 14 09:14:51.819: cc_api_get_xcode_stream : 4803
Feb 14 09:14:51.819: //3735/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 14 09:14:51.819: //3735/2E9C7A979334/CCAPI/cc_api_call_proceeding:
Feb 14 09:14:52.155: //3735/2E9C7A979334/CCAPI/cc_api_call_alert:
Feb 14 09:14:52.159: //3734/2E9C7A979334/CCAPI/ccCallAlert:
Feb 14 09:14:55.067: //3735/2E9C7A979334/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=3735,
Feb 14 09:14:55.067: //3734/2E9C7A979334/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=3735, Source Call Id=3734,
Feb 14 09:14:55.067: //3735/2E9C7A979334/CCAPI/cc_api_event_indication:
   Event=175, Call Id=3735
Feb 14 09:14:55.067: //3735/2E9C7A979334/CCAPI/cc_api_call_connected:
   Connection Handle=0
Feb 14 09:14:55.067: //3734/2E9C7A979334/CCAPI/ccConferenceCreate:
   (confID=0x2B774E78, callID1=0xE96, gcid=2E9D1758-562311E1-93378E15-E3B21876, tag=0x0)
Feb 14 09:14:55.067: //3735/2E9C7A979334/CCAPI/ccConferenceCreate:
   (confID=0x2B774E78, callID2=0xE97, gcid=2E9D1758-562311E1-93378E15-E3B21876, tag=0x0)
   Conference Id=0x2B774E78, Call Id1=3734, Call Id2=3735, Tag=0x0
Feb 14 09:14:55.067: //3734/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 14 09:14:55.067: cc_api_get_xcode_stream : 4803
Feb 14 09:14:55.067: //3735/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 14 09:14:55.067: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=6
Feb 14 09:14:55.067: //3734/2E9C7A979334/CCAPI/cc_api_bridge_done:
   Conference Id=0xD5, Source Interface=0x30AF2250, Source Call Id=3734,
   Destination Call Id=3735, Disposition=0x0, Tag=0x0
Feb 14 09:14:55.071: //3735/2E9C7A979334/CCAPI/cc_api_bridge_done:
   Conference Id=0xD5, Source Interface=0x30AF2250, Source Call Id=3735,
   Destination Call Id=3734, Disposition=0x0, Tag=0x0
Feb 14 09:14:55.071: //3734/2E9C7A979334/CCAPI/cc_generic_bridge_done:
Feb 14 09:14:55.071: //3734/2E9C7A979334/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xD5, Destination Call Id=3735)
Feb 14 09:14:55.071: //3735/2E9C7A979334/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xD5, Destination Call Id=3734)
Feb 14 09:14:55.071: //3734/2E9C7A979334/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xD5, Call Id1=3734, Call Id2=3735
Feb 14 09:14:55.071: //3734/2E9C7A979334/CCAPI/ccCallConnect:
Feb 14 09:14:55.423: //3734/2E9C7A979334/CCAPI/cc_api_event_indication:
   Event=197, Call Id=3734
Feb 14 09:14:58.371: //3735/2E9C7A979334/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=3735
Feb 14 09:14:58.375: //3735/2E9C7A979334/CCAPI/cc_api_remote_codec_dnld_done:
   Destination Interface=0x30AF2250, Destination Call Id=3735, Source Call Id=3734, Xmit Function=0x25D27958
Feb 14 09:14:58.375: //3735/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 14 09:14:58.375: cc_api_get_xcode_stream : 4803
Feb 14 09:14:58.375: //3734/2E9C7A979334/CCAPI/cc_api_caps_ind:
Feb 14 09:14:58.375: //3735/2E9C7A979334/CCAPI/cc_api_caps_ack:
   Destination Interface=0x30AF2250, Destination Call Id=3734, Source Call Id=3735,
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=9640)
   Caps(Codec=gsmefr(0x0), Fax Rate=Invalid(0x0), Vad=Invalid(0x0),
   Modem=OFF(0x0), Codec Bytes=0, Signal Type=0, Seq Num Start=0)
Feb 14 09:14:58.375: //3734/2E9C7A979334/CCAPI/cc_api_event_indication:
   Event=174, Call Id=3734
Feb 14 09:14:58.375: //3734/2E9C7A979334/CCAPI/cc_api_call_feature:
   Feature Type=50, Interface=0x30AF2250, Call Id=3734
Feb 14 09:14:58.375: //3735/2E9C7A979334/CCAPI/cc_api_event_indication:
Feb 14 09:14:58.375: //3734/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 14 09:14:58.715: //3735/2E9C7A979334/CCAPI/cc_api_caps_ind:
Feb 14 09:14:58.715: //3734/2E9C7A979334/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1984)
   Caps(Codec=gsmefr(0x0), Fax Rate=Invalid(0xAD0051), Vad=Invalid(0x12C0000),
   Modem=OFF(0x0), Codec Bytes=1, Signal Type=0, Seq Num Start=0)
Feb 14 09:14:58.715: //3735/2E9C7A979334/CCAPI/cc_api_event_indication:
Feb 14 09:14:59.023: //3734/2E9C7A979334/CCAPI/cc_api_call_facility:
Feb 14 09:14:59.023: //3734/2E9C7A979334/CCAPI/cc_api_event_indication:
Feb 14 09:15:02.955: //3734/2E9C7A979334/CCAPI/ccGenerateToneInfo:
   Tone Direction=Sum Network, Params=0x0, Call Id=3734
Feb 14 09:15:02.955: //3735/2E9C7A979334/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x30AF2250, Call Id=3735
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Feb 14 09:15:02.959: //3734/2E9C7A979334/CCAPI/ccConferenceDestroy:
   Conference Id=0xD5, Tag=0x0
Feb 14 09:15:02.959: //3734/2E9C7A979334/CCAPI/cc_api_bridge_drop_done:
Feb 14 09:15:02.959: //3735/2E9C7A979334/CCAPI/cc_api_bridge_drop_done:
Feb 14 09:15:02.959: //3734/2E9C7A979334/CCAPI/cc_generic_bridge_done:
Feb 14 09:15:02.959: //3734/2E9C7A979334/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Feb 14 09:15:02.959: //3735/2E9C7A979334/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Feb 14 09:15:02.959: //3735/2E9C7A979334/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30AF2250, Tag=0x0, Call Id=3735,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Feb 14 09:15:02.959: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 14 09:15:02.959: :cc_free_feature_vsa freeing 40007270
Feb 14 09:15:02.959:  vsacount in free is 3
Feb 14 09:15:02.959: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
   data = 2CD0E5C8
Feb 14 09:15:02.959: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(321741B4)=0 - mempool cleanup
Feb 14 09:15:03.271: //3734/2E9C7A979334/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30AF2250, Tag=0x0, Call Id=3734,
Feb 14 09:15:03.271: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 14 09:15:03.271: :cc_free_feature_vsa freeing 400070B0
Feb 14 09:15:03.271:  vsacount in free is 2
Feb 14 09:15:05.551: //3733/49ACC544AF19/CCAPI/ccGenerateToneInfo:
   Tone Direction=Sum Network, Params=0x0, Call Id=3733
Feb 14 09:15:05.551: //3732/49ACC544AF19/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x30AF2250, Call Id=3732
Feb 14 09:15:05.551: //3732/49ACC544AF19/CCAPI/ccConferenceDestroy:
   Conference Id=0xD4, Tag=0x0
Feb 14 09:15:05.551: //3732/49ACC544AF19/CCAPI/cc_api_bridge_drop_done:
Feb 14 09:15:05.551: //3733/49ACC544AF19/CCAPI/cc_api_bridge_drop_done:
Feb 14 09:15:05.551: //3732/49ACC544AF19/CCAPI/cc_generic_bridge_done:
Feb 14 09:15:05.551: //3732/49ACC544AF19/CCAPI/ccCallDisconnect:
Feb 14 09:15:05.551: //3733/49ACC544AF19/CCAPI/ccCallDisconnect:
Feb 14 09:15:05.555: //3732/49ACC544AF19/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30AF2250, Tag=0x0, Call Id=3732,
Feb 14 09:15:05.555: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 14 09:15:05.555: :cc_free_feature_vsa freeing 400077B0
Feb 14 09:15:05.555:  vsacount in free is 1
Feb 14 09:15:05.883: //3733/49ACC544AF19/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30AF2250, Tag=0x0, Call Id=3733,
Feb 14 09:15:05.883: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 14 09:15:05.883: :cc_free_feature_vsa freeing 40007190
Feb 14 09:15:05.883:  vsacount in free is 0
Feb 14 09:15:05.883: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
   data = 2CD0DEC8
Feb 14 09:15:05.883: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(2B7903A8)=0 - mempool cleanup
Everyone's tags (2)
1 REPLY
Hi Damien,
Have you any update on this issu ?
Best regards,
Matthieu
1449
