CME 9.0 Upgrade Registration Rejected Max Phones Exceeded
Recently upgrade to CME 9.0 and after ios and phone firmware upgrade I received the error Reg Rej - Max Phones... The CME was operational prior to the upgrade, Show license all showed the license active and the EULA accepted, Telephony-service had existing max-ephones configured. Entered the max-ephone command again with same information and I was prompted for the EULA to accept and phones began to register. Just wanted to put this out there for anybody else that comes across this problem.
  • IP Telephony
Hall of Fame Super Red
Hey Jeremy,
Ashraf was having this exact same issue yesterday, so thanks
for posting up your solution If you can give us a reply we can award
the points your kind gesture deserves.
Cheers!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
No problem, hope it helps someone.
Hello Jeremy,
I also faced the same issue today.
I did the same as you mentioned earlier in the first comment
But my license is showing it as 60 days trail version
I had complete license earlier to this deployment
Can you help me here
Hall of Fame Super Gold
Possibly you are referring to a demonstration UC license that has expired.
This license must be purchased and CME will not work without it.
Hi I have a similar issue i'm
Hi I have a similar issue i'm working on a lab. I have a voice-register pool and ephone configured, the sip phone registers without any issue but the sccp phone gives me the message "registration rejected max ephone exceeded"
so what I did was increase the max-ephone but when debugging 'debug ephone register'  the phone registration count goes to 1 above the configured max-ephone value. and the phone registration is rejected.
its really frustrating - I have a permanent uck9 license and can't figure out what is going on. I'm running 2911 15.2.4.M6 and have also tried M6 and experienced the same results.
my understanding is the uck9 lic controls the cucme aspect. (which is permanent)
please please help.
right so after a nights sleep
right so after a nights sleep i have figured this our - on my telephony-service config i tried to disable auto reg but accidently enabled no reg-ephone, the side effects of that is the cucme prevents the phone from registrating by incrementing the max-ephone reg number by 1 so if you have max-ephone set to say 5 and you have no reg-ephone enabled the cucme wil increment to the count to 5 and the next registration event is rejected with the message max ephone exceeded.
Dear Sir,
How are you ? Merry Christmas and happy new year ?? Kindly could you help me please ? I see the article about
Phone-Reg-Rej problem (registration rejected max phones exceeded ), Which you wrote it on Cisco support community
I have 2901 Voice gateway ,
I do the following :
1-   Change the Voice IOS for the router as  :-
-      c2900-universalk9-mz.SPA.152-4.M3.bin (V 9.1 Telephon-service ).
-      c2900-universalk9-mz.SPA.151-4.M3.bin (V 8.6 Telephony-Service )
-      c2900-universalk9-mz.SPA.154-1.T.bin  (V10 Telephony-Service)
2-     use this CLI Command license accept end user agreement then yes
3-     Remove Telephony-Service and return it again
4-      I use different IP Phones Like (7975,6921, ....etc) and all have the same above problem.
Sir if you have any solve to my problem please send it to me ?? Thanks
VIP Purple
Ho Rashid,
what is the total number of IP phones you have on CME version 10?
From the compatibility matrix,I can see total number of SIP and SCCP phones on 2901 should be 35.
regds,
aman
yes its 35 user (Extensions), but i connect just 1 IP Phone which is 6921 , Phone not registered and the message still display??!!
and the Following is my code :
Current configuration : 3676 bytes
! Last configuration change at 15:49:54 UTC Sun Jun 8 2014
! NVRAM config last updated at 15:50:04 UTC Sun Jun 8 2014
version 15.4
hostname Router
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.154-1.T.bin
boot-end-marker
aqm-register-fnf
enable secret 5 $1$psKM$XjaK30brJR7LeNrh3Bx4g/
no aaa new-model
ip dhcp excluded-address 10.1.1.200 10.1.1.254
ip dhcp excluded-address 10.1.1.2 10.1.1.10
ip dhcp pool Voice
network 10.1.1.0 255.255.255.0
option 150 ip 10.1.1.1
dns-server 192.168.1.1 4.2.2.2
domain-name lastvision-sa.com
default-router 10.1.1.1
ip cef
no ipv6 cef
voice-card 0
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711alaw
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  registrar server expires max 3600 min 1800
voice register global
mode  cme
source-address 10.1.1.1 port 5060
max-dn 100
load 9951 sip9951.9-4-1-9.loads
authenticate register
authenticate realm cisco.com
tftp-path flash:
file text
create profile sync 000005124105141A
camera
video
license udi pid CISCO2901/K9 sn FGL155224LH
license boot module c2900 technology-package datak9
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
ip address 10.1.1.1 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
tftp-server flash:SCCP69xx.9-2-1-0.loads
tftp-server flash:SCCP69xx.9-2-1-0.zz.sgn
tftp-server flash:DSP69xx.0-0-0-8.zz.sgn
tftp-server flash:BOOT69xx.0-0-0-14.zz.sgn
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 10.1.1.1 identifier 1 version 7.0
sccp
sccp ccm group 1
associate profile 1 register mtpfc994766c351
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
maximum sessions 4
associate application SCCP
shutdown
gatekeeper
shutdown
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 4
sdspfarm tag 1 mtpfc994766c351
no auto-reg-ephone
max-ephones 35
max-dn 150
ip source-address 10.1.1.1 port 2000
load 7916-12 B016-1-0-4-2.SBN
load 6921 SCCP69xx.9-2-1-0.loads
time-zone 30
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
moh enable-g711 "en_bacd_music_on_hold.au"
multicast moh 239.1.1.1 port 16392 route 10.1.1.1 10.1.1.200
web admin system name admin password cisco
transfer-system full-consult
create cnf-files version-stamp 7960 Jun 08 2014 15:49:50
ephone-dn  1
number 444
name Rasheed
ephone  1
mac-address 0007.7D43.6CC2
type 6921
button  1:1
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
6001
