CME 9.1, 7945 & 9.3(1SR1) Firmware
Guys,
CME 9.1 comes bundled with 9.2(1) firmware.
7945's come out of the box with 9.3(1) firmware.
CME 9.1 does not list 9.3(1) firmware as supported
When you plug a 7945 into a CME 9.1 system with 9.2(1) firmware, the phone says "upgrading" and then fails, reverts back to 9.3(1) firmware and works on that.  Each time it is reset, it tries to upgrade and fails.  The error message is the "Load Rejected HC" one.  This seems to say the firmware is not compatible with that hardware...another guy had a similar issue.
https://supportforums.cisco.com/thread/2228487?tstart=0
If you factory reset the phone, it will not work at all, it just resets constantly, trying to upgrade to 9.2(1) but fails, it never even gets past the upgrading screen so you cannot check the log.
The only fix I've found for phones in this state is to put 9.3(1) firmware on the flash of the CME and tell the phones to use that, they then seem to work fine, however it is not listed as supported for CME 9.1, 9.2(1) is the highest:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme91spc.html
Has anyone had this issue or knows what to do?
I am unable to get my 7945 phones on to 9.2(1) at the moment.  My options seem to be to either just leave the phones as they are, let them fail an upgrade every boot and run 9.3(1) firmware, or to actually tell CME to use 9.3(1) and run in an unsupported configuration.
Any ideas? Thanks!
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Carl,
The 9.3(1) firmware would be "fully" supported on CME 9.1. The supported
firmware that you see in the CME matrix is what was available and considered
stable at the time CME 9.1 was released and is not updated as new firmware
releases come down the pipe
If in doubt, I would open a TAC case to confirm the independent nature of
the relationship between CME and supported firmware versions.
Here is that note that is causing the issues you are seeing;
Hardware Updates
The hardware updates improve the compatibility of internal phone components.
The following table lists the updated hardware versions that require this release.
Phone
Hardware Version
Cisco Unified IP Phone 7942G
15.0 and higher
Cisco Unified IP Phone 7962G
15.0 and higher
Cisco Unified IP Phone 7945G
13.0 and higher
Cisco Unified IP Phone 7965G
13.0 and higher
Cisco Unified IP Phone 7975G
12.0 and higher
Phones manufactured with these hardware versions must run Firmware  Release 9.3(1)SR1 or later. The phone firmware does not allow the phone  to be downgraded to releases earlier than Release 9.3(1)SR1.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7900_series/firmware/9_3_1SR1/release_notes/P790_BK_R4E1E768_00_rn-9_3_1_sr1-7900-series_chapter_00.html#P790_RF_ND56648A_00
Cheers!
Rob
"I don't know how, I don't know when
But you and I will meet again "
- Tom Petty
Hall of Fame Super Gold
Re: CME 9.1, 7945 & 9.3(1SR1) Firmware
Firmare is not that important unless you run into bugs, so running firmware from that list is not mandatory. You can run 9.3 or anything else without issue.
Hi Carl,
Yes, you should be good to go with the 9.3(1) firmware The firmware useage
should be completely independent of the CME version.
Cheers!
Rob
- Tom Petty
Ok great, thanks;  I always try to follow what Cisco say with regard to supported firmware, I was just wondering if there was any solution in this case.
Hi Carl,
Hardware Updates
Phone
Hardware Version
15.0 and higher
15.0 and higher
13.0 and higher
13.0 and higher
12.0 and higher
Cheers!
Rob
- Tom Petty
2677
