Community Member
CME 9.1 CIPC backgroung image change
Good morning, I need to change the background image on my  CIPC registered on  CME 9.1
I followed all suggested items but  when  I try to chang the background image the nìmessage " selection unavailable appears.
 The router config  is the following:
tftp-server flash:/Desktops/320x212x12/List.xml
tftp-server flash:/Desktops/320x212x12/CampusNight.png
tftp-server flash:/Desktops/320x212x12/CiscoLogo.png
tftp-server flash:/Desktops/320x216x16/List.xml
tftp-server flash:/Desktops/320x212x16/List.xml
the flash  contain all  files in the correct directories
show flash:
78          0 Apr 15 2014 08:44:00 +02:00 Desktops
279          0 Apr 15 2014 08:44:16 +02:00 Desktops/320x212x12
280        726 Apr 15 2014 14:08:16 +02:00 Desktops/320x212x12/List.xml
282     131470 Apr 15 2014 14:06:56 +02:00 Desktops/320x212x12/CampusNight.png
283       8156 Apr 15 2014 14:07:20 +02:00 Desktops/320x212x12/CiscoLogo.png
284     138278 Apr 15 2014 14:08:14 +02:00 Desktops/320x212x12/Fountain.png
285     109076 Apr 15 2014 14:09:04 +02:00 Desktops/320x212x12/MorroRock.png
286     108087 Apr 15 2014 14:09:36 +02:00 Desktops/320x212x12/NantucketFlowers.png
287      10820 Apr 15 2014 14:09:40 +02:00 Desktops/320x212x12/TN-CampusNight.png
288       2089 Apr 15 2014 14:09:44 +02:00 Desktops/320x212x12/TN-CiscoLogo.png
289       7953 Apr 15 2014 14:09:46 +02:00 Desktops/320x212x12/TN-Fountain.png
290       7274 Apr 15 2014 14:09:48 +02:00 Desktops/320x212x12/TN-MorroRock.png
291       9933 Apr 15 2014 14:09:52 +02:00 Desktops/320x212x12/TN-NantucketFlowers.png
292          0 Apr 15 2014 13:46:36 +02:00 Desktops/320x216x16
293          0 Apr 15 2014 13:46:44 +02:00 Desktops/320x212x16
294        726 Apr 15 2014 14:09:54 +02:00 Desktops/320x212x16/List.xml
295        726 Apr 15 2014 14:09:52 +02:00 Desktops/320x216x16/List.xml
296      80565 Apr 15 2014 14:07:18 +02:00 Desktops/320x212x12/CiscoFountain.png
297       9657 Apr 15 2014 14:09:44 +02:00 Desktops/320x212x12/TN-CiscoFountain.png
Problem: You go to the
Problem: You go to the Background Images menu on your IP Phone, but the "Selections Unavailable" message comes up, some phones may show the thumbnails just fine.
Solution 1: After saving the  file with some text editors, eventhough you specify an .xml extension,  the program might add a .txt at the end. Erase it.
Solution 2: open an SSH session to the CallManager node where the XML and PNG files  were uploaded. run this command, make sure the files were correctly  uploaded:
  • file list activelog cm/tftpdata/Desktops/320x212x16
If not, then you uploaded them to another node, or there is something wrong with the TFTP transaction
Solution 3: open the List.xml file with a browser. If it shows a syntax error, then  there is a quote, bracket or other mistake in the XML syntax. No files  will be shown in the phone. A good syntax should look like this in your  browser:
https://supportforums.cisco.com/document/44191/how-modifychange-background-image-ip-phone-new
Manish
Community Member
Hi Manish.I followed yours
Hi Manish.
I followed yours suggestions but all appears ok
1 the file is a.xml
2 my device is a CME and not a CM
3 I've used an  original cisco  List.xml file.
But the result is Always the same
Can you please send across
Can you please send across "debug tftp events"  from the CME router when you try to change background image of the phone.
Manish
Community Member
CCME-LAB#deb tftp evenCCME
CCME-LAB#deb tftp events
TFTP Event debugging is on
CCME-LAB#ter mon
CCME-LAB#
*Apr 16 09:31:56.239: TFTP: Looking for CTLSEP00269EC065E9.tlv
*Apr 16 09:32:01.383: TFTP: Looking for Desktops/320x212x12/List.xml
Does List.xml contains image
Does List.xml contains image location correctly ?
Check by  " more flash:/Desktops/320x212x12/List.xml" or paste the output here.
Manish
Community Member
CCME-LAB#more flash:/Desktops
CCME-LAB#more flash:/Desktops/320x212x12/List.xml
<CiscoIPPhoneImageList>
<ImageItem Image="TFTP:Desktops/320x212x12/small1.png"
URL="TFTP:Desktops/320x212x12/big1.png"/>
<ImageItem Image="TFTP:Desktops/320x212x12/TN-CiscoFountain.png"
URL="TFTP:Desktops/320x212x12/CiscoFountain.png"/>
<ImageItem Image="TFTP:Desktops/320x212x12/TN-Fountain.png"
URL="TFTP:Desktops/320x212x12/Fountain.png"/>
<ImageItem Image="TFTP:Desktops/320x212x12/TN-MorroRock.png"
URL="TFTP:Desktops/320x212x12/MorroRock.png"/>
<ImageItem Image="TFTP:Desktops/320x212x12/TN-NantucketFlowers.png"
URL="TFTP:Desktops/320x212x12/NantucketFlowers.png"/>
<ImageItem Image="TFTP:Desktops/320x212x12/TN-CiscoLogo.png"
URL="TFTP:Desktops/320x212x12/CiscoLogo.png"/>
</CiscoIPPhoneImageList>
Try by changing xml file like
Try by changing xml file like this....
<ImageItem Image="flash:Desktops/320x212x12/CiscoFountain.png"
URL="flash:Desktops/320x212x12/
Or
<ImageItem Image="flash:/Desktops/320x212x12/CiscoFountain.png"
URL="flash:/Desktops/320x212x12/
And then send across "debug tftp events"
Manish
Community Member
with<ImageItem Image="flash
with
 the  debug tftp event is
CCME-LAB#
*Apr 16 10:07:17.623: TFTP: Looking for CTLSEP00269EC065E9.tlv
*Apr 16 10:07:20.287: TFTP: Looking for Desktops/320x212x12/List.xml
with
The debug tftp event is
CCME-LAB#
*Apr 16 10:11:13.251: TFTP: Looking for CTLSEP00269EC065E9.tlv
*Apr 16 10:11:15.871: TFTP: Looking for Desktops/320x212x12/List.xml
Nothing is changed
thanks
Ignore my previous comment it
Ignore my previous comment it should be "TFTP:Desktops/320x212x12/".
Now after phone Looking for list.xml , it should deliver all listed image in thumbnails on the phone screen , if its not then it might be bad xml file , case mismatch or bad file names.
https://supportforums.cisco.com/discussion/11363836/cme-and-phone-background-images
Community Member
Try to Alias  command as with
Try to Alias  command as with Tftp path
Community Member
Can post the List.xml file
Can you please post the List.xml file here.
347
