For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
cme 9.1 parked calls question
i have a need to do this with park call.
  1. Call comes in.
  2. Reception at ext 4026  answer call.
  3. Reception transfer all to my extension ext 4047.
  4. Call automatically goes to my extension as parked. (I don’t want to pickup for 2 minutes). I have created two ext just for parked (4052 & 4053)
  5. After 2 minutes I pickup call from park at my desk.
is there anyway to do that?
dangquangminh@vnpro.org CCIE#11897 6016 Tillsdows Dr, Mississauga,ON Canada L5N4M3
  • IP Telephony
1 ACCEPTED SOLUTION
No, you would need to take
No, you would need to take the call and park it.
Or have the reception park it, then you pick it up.
java
if this helps, please rate
www.cisco.com/go/pdi
1 REPLY
java
15
