Community Member
CME - 9.5 abbreviated internal dialing. (+E164 to 5 digits)
Hello All,
I am searching for an solution to allow CME users to dial +E164 DN (+33 and 9 digits) internal extensions as an abbreviated dial using "#" followed by the last four digits of the extension...
I 've created a translation rule and profile.... but how I can assign it to the telephony-service configuration ?
voice translation-rule 5000
rule 1 /^#\(5...$\)/ /+3312345\1/
voice translation-profile Trans-Interne
translate called 5000
I've created also a dial peer pots in which I've applied the translation profile....
it should not be difficult. Could you help me, please ?
Best Regards,
Christian.
Hall of Fame Super Gold
You can use translation under ephone-dn, or bulk speed-dial, etc.
Community Member
Thanks for your answer.
I have about two hundred ephone-dn... So I have to use the translation under all ?
I'm going to try with one first.
Ch.
Normally not needed with proper configuration. But each case is different.
Community Member
Hi (again) !
what is this command secondary in the ephone-dn ?
"ephone-dn  1  dual-line
number +3312345678 secondary ?????
Can it be use for abbreviated dialing ?
Community Member
I would stay with the translation pattern under the dial peer. No reason to put it under the ephone-dn, I believe.
Why is that not good for you?
Also, what problem are you experiencing right now?
Francesco
Community Member
Hi Francesco,
I get a busy tone as soon as I dial # and 5... or any other digits.
(calling with full E164 DN is ok.)
Ch.
Community Member
Hi All !
It's Ok.
I found that "#" can't be used as a digit. it is used to prevent waiting the "inter-digit timeout"....
So I change it to "F" as example.
And I used the secondary DN in the "ephone-dn" configuration, that is :
dial-peer terminator F
number +33123456789 secondary #6789
label TEST 1
name TEST 1
corlist incoming CSS-International
ephone-dn  2  dual-line
number +33123456788 secondary #6788
label TEST 2
name TEST 2
Thanks for your help,
Best regards,
Ch.
232
