CME: Ad-Hoc Multiparty Conferencing Problem
I am trying to configure DSPFarm for ad-hoc multiparty conferencing as per documentation but when i try to configure maximum session in "dspfarm profile 2 conference", the available value is just 0. and when i execute sh dspfarm all command, the output you can see below:
CME#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 2, Service = CONFERENCING, Resource ID = 1
Profile Description :
Profile Admin State : DOWN
Profile Operation State : DOWN
Application : SCCP Status : NOT ASSOCIATED
Resource Provider : FLEX_DSPRM Status : NONE
Number of Resource Configured : 0
Number of Resource Available : 0
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
Total number of DSPFARM DSP channel(s) 0
CME#sh inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811 , VID: V05 , SN: FCZ120872XE
NAME: "WAN Interface Card - Serial (1T) on Slot 0 SubSlot 0", DESCR: "WAN Interface Card - Serial (1T)"
PID: WIC-1T= , VID: 1.0, SN: 36242834
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 1", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1 , VID: V01 , SN: FOC12122L32
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO , VID: V03 , SN: FOC12081UJ3
NAME: "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16 , VID: V01 , SN: FOC11525U28
NAME: "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16 , VID: V01 , SN: FOC12085AAK
NAME: "AIM Service Engine 0", DESCR: "AIM Service Engine"
PID: AIM-CUE , VID: V03 , SN: FOC12043MQE
If you think there is any problem with configuration, please write down sample steps for Ad-Hoc Conferencing for more then 3 participants.
Waiting for immediate response
Note: i am using CME on cisco 2811 with ios c2800nm-spservicesk9-mz.124-15.T5.
  • IP Telephony
2 ACCEPTED SOLUTIONS
VIP Super Bronze
Re: CME: Ad-Hoc Multiparty Conferencing Problem
when you see maximum number of seesion to be "0" that measn that you do not have dsp resources for conferencing.
You may have configured your pri to use all the dsp resources you have.
To resolve this you will need to either add more dsp (pvdms) or reconfigure your pri to use only a few of the dsps so you can have some left for conferencing..
Your best bet, is to use the dsp calculator to calculate the dsp required for voice calls and conferencing
http://www.cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hall of Fame Super Red
Hi Rameez,
Just to add a note to confirm Deji's great assessment here (+5 points for you Deji :)
You can not share a DSP between voice termination ports and conference bridges.
Allocation of DSP Resources Within the Voice Network Module
You allocate DSP resources either to voice termination of the voice trunk group or to the DSP farm. Occasionally these allocations can conflict.
If you previously allocated DSP resources to voice termination and you now try to configure a DSP farm, you might find that insufficient DSP resources are available. Conversely, if you previously allocated DSP resources to a DSP farm and you now try to configure a trunk group, you might find that insufficient DSP resources are available.
If your requested configuration is rejected, you have two options:
•Insert more DSPs on the voice network module (NM-HDV or NM-HDV2)
•Allocate a different voice network module for either the DSP farm or the trunk group
http://www.cisco.com/en/US/docs/ios/voice/cminterop/configuration/guide/vc_enh_confr_vgr.html#wp1040335
Hope this helps!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
VIP Super Bronze
Hi Rameez,
Hope this helps!
Rob
VIP Super Bronze
Rob,
Thanks for the nice rating!
329
