Community Member
CME - Adding a prefix to callerid for incoming calls
Hi everyone,
Is it possible to manipulate the caller id for the incoming calls? This is my situation:
The same CME will be used for 3 different companies (A, B, C), having a pool of agents answering the calls for the 3 companies with a different greeting for each of them, so they will need to know what number was dialed by the customer to determine which greeting to use.
We will be using a 2821 CME 7, having an E1 to PSTN, receiving 10 lines for each company through the E1.
Is it possible to add like A, B or C (Company A, Company B, Company C) as a prefix to the caller id to differentiate the dialed number?
Any help will be apreciated.
Thanks in advance.
JS
1 REPLY
Re: CME - Adding a prefix to callerid for incoming calls
I don't believe this is possible.  You could, however, prefix a numerical identifier using translation-profiles/translation-rules.
Something like this:
voice translation-rule 10
rule 1 /\(.*\)/ /1*\1/
voice translation-profile companyA
translate calling 10
dial-peer voice 10 pots
description Company A
incoming called-number
direct-inward-dial
translation-profile incoming companyA
So a call from 2025551212 would present on the phone as *1*2025551212.  Granted, it isn't pretty.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
675
