I'm not seeing where to enable Alerting Name Display for CME when called from a CM phone via an H.225-GK Trunk. CME IOS verion is 12.4(5c) [CME 3.3].
The Alerting Name Display works when CME calls CM, but not when CM calls CME. I see a difference in the Call Proceeding that comes from the CME that may be the problem. I don't see a "Data" information field that is there when from CM. I tried several things to remedy, but none of these worked:
(config-dial-peer)#signaling update from ...
(conf-voi-serv)#supplementary-service h225-notify cid-update
(config-dial-peer)#progress_ind
(conf-serv-h323)#telephony-service ccm-compatible
(config)#voice call send-alert
Here is the Call Progress from the CCM:
value H323_UserInformation ::=
h323-uu-pdu
h323-message-body callProceeding :
protocolIdentifier { 0 0 8 2250 0 2 }
destinationInfo
terminal
mc FALSE
undefinedNode FALSE
callIdentifier
guid 'BBE40DE18A7911DC8074F17F39C43B96'H
h245Tunneling FALSE
nonStandardControl
nonStandardIdentifier h221NonStandard :
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '80A4000400010100'H
//and here is the PROCEEDING FROM CME
h323-uu-pdu
protocolIdentifier { 0 0 8 2250 0 4 }
destinationInfo
vendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
gateway
protocol
voice :
supportedPrefixes
}, h323 :
supportedPrefixes
mc FALSE
undefinedNode FALSE
callIdentifier
guid '802DF5C545A9D11D0B0059010A01C8CB'H
multipleCalls FALSE
maintainConnection FALSE
h245Tunneling FALSE
